I am in the early stages of adding scenery to my plywood pacific layout. A large area along my layout is supposed to run along sandy beaches in Southern California. Thus, I need some kind of material to help me create the undulating terrain of sand beaches. I thought I could use Sculptamold but none of the LHS’s in my area carry it. One shop had bags of ClayCrete which they discribed as being similar to Sculptamold. I bought a bag ($8) and quickly went through about half of it creating small sand dunes and other terrain in other scenes. I found the ClayCrete product to be relatively clean, it adheres well to plywood, and it can be easily shaped. However, I found the cured and painted material to be fairly soft and easily damaged exposing its snow white color. It also has a tendency to shrink a bit when drying. I also realized that I was going to need a lot of it for my 10’ by 19’ double-deck layout.
Looking a little closer at this stuff, I realized that all I needed was some form of filler material to mix with a binder. Several years ago, my wife (thinking I might have a use for it) brought home several small bags of papier mache powder that someone was going to throw out. Okay, I’ve got a good supply of a binder. Now all I needed was a filler material. Looking around my garage, my eyes landed on the canvas catch bag beneath my table saw chuck full of sawdust. Hey, that might work as filler! Mixing a few handfuls of sawdust with some papier mache powder and water gave me a sloppy mix that could be spread and formed using just my fingers into whatever terrain shape I needed (I could apply it mcuh thicker if needed, too). I found that this mix dried into a more solid surface than the ClayCrete, it maintains a tan color instead of the snow white of the ClayCrete, and it doesn’t seem to shrink. I also discovered that I can sand the cured mix to smooth it or to match it to an adjacent s
Using Durabond as a substitute for the Claycrete will work well also. Add your fillers to the consistancy you need. A bit of masonry dye can help to get a closer color for the overall base for added scenery material, sand, ground foams etc.
Hopefully Drwayne will post some of his pics and describe methods of mix, I believe his formula may be just what your looking for.
Well, I’ll stick with my Sculptamold, even though it ain’t cheap. I get it by the 5 lb bag at Michaels using a coupon, and it’s not too bad. I mix a little brown, red, and gray tempura powder with the Sulptamold before I apply it, so even of it chips, it doesn’t show white.
There are eight and forty ways of creating scenic surfaces, and every single one of them is right. (With apologies to Rudyard Kipling.)
It sounds as if you’ve discovered a nice, inexpensive (for you) source of the ingredients for a useable form of ground goop. The only thing I would add is powdered coloring material to more closely match whatever the local base level dirt is supposed to look like.
Since I’m a long way away from needing to make final decisions on how to finish my landforms I’m collecting suggestions like this one. As for which one(s) I’ll actually use, the jury hasn’t even been selected yet.
Chuck (Modeling Central Japan in September, 1964 - eventually)
You’re quite right Chuck about there being so many ways to do things. I just thought I’d share a method I found for my layout. Since most of us create a bunch of sawdust building our benchwork, recycling this waste into “ground goop” might turn out to be popular with some modelers.
For a cheap, rolling dunes base, wad up a little newspaper, shape it to your basic liking. Dip some sheets of newspaper in a white glue (glue shell) and lay the sheets over the lumps. When dry, paint it and sprinkle sand right into the wet paint. Add some grass tuffs.
One well known modeler here in Milwaukee as been using the interior foam from the Instapak foam packaging material (that comes in the silvery gray bags) that more and more electronics and other stuff comes packed with. It is easily broken by hand, easily shaped, is very light but strong, and has a texture that lends itself to scenicking. It also takes on interesting shapes as part of the expanding nature of the product – expands to fit the item packaged.
Best of all many places and many people just throw it away (although it can and should be recycled).
Cheap? Land? Hey, I got a whole field full of the stuff. Sift it out and bake it, and mark it with a “T”…
No wait, I was getting carried away there, But dirt, Rocks, Trees, they can all be brought in from the back yard (assuming you have three square miles of backyard).
Crumbling brick dust from one of our buildings also worked well to.
Some times the city spreads fine gravel on the street because of snow. The gravel eventually finds it’s way to the gutter. Some of it has been ground pretty fine from the cars running over it. Along with this gravel the grit from roof shingles makes it’s way to the gutter from the down spouts that drain to the street.
Of course you need to wash and put it through a strainer and a magnet to be safe should be used.
