The new CIROC control center has opened. Will this improve transit times ? Seems like a good location for Trains Mag to visit and write an article.
CREATE Program info@createprogram.org CREATE Applauds Rail Industry for Opening Rail Traffic Management Facility Pictured: The main control room inside the Chicago Integrated Rail Operations Center (CIROC) Freight railroads operating in C
Just my two cents worth, but wouldn’t it be more efficient to remove from Chicago traffic that doesn’t need to go there? It might be, but no one is willing to pay the price. They must enjoy whining about the delays.
Over the years all the carriers have worked out interchange plans for their normal traffic to determine the most efficient manners and locations for all the carriers involved in the move. The outgrowth of these interchange plans has been the growth of ‘run-through trains’ between carriers that move from major classification terminal to major classification terminal on both sides of Chicago (and the other gateway areas) and the trains at most stop in Chicago (or other gateways) for a most a crew change. Other trains bring Chicago Switching area traffic to Chicago to be switched to the customers. One thing many overlook about Chicago is the amount of traffic that actuall goes to customers in the Chicago Switching area.
The multi-carrier control center was an idea that has been more than twenty years in bringing to fulfillment. Being able to interact on a face to face basis with all the controlling parties in real time is something the Chicago area has never had - dealing with real people beats dealing with disembodied voices over telephones that are not answered in a timely fashion by seveal thousand percent. While telephones may permit communication, they also generate frustrations and develop a ‘us vs. them’ bunker mentality.
There used to be outer belt lines south of Cicago, and car ferries north of Chicago across Lake Michigan that advertised they avoided the congestion, but most of the outer belt lines are gone or little used, and all the car ferries are gone. St Louis is also underutilized. The western lines want the longer haul to Chicago.
The Lake Michigan carferries, with the exception of the routes to Kewaunee, were not really intended as Chicago bypass routes. They did give customers on the western shore of the lake better rates to eastern markets.
Rate divisions under ICC regulation go a long way in explaining why bypass routes like the EJ&E, TP&W and the Kankakee Belt were under-utilized in either direction.
CN is using the former Outer-Belt, the EJ&E, to reduce Chicago congestion, but there is not much more additional capacity to handle pairs of carriers’ traffic that dooesen’t interchange with CN. St. Louis is also congested at this time, and connections to the east are more limited than they were and more limited than Chicago.
The CIROC is useless, nothing more than a window dressing so it looks aa like something is being done. It has no power, and at best is a mediator between railroads. It is a punchline in the Chicago railroad scene.
I never understood the relatively new practice of CP trains waiting just beyond METRA territory, North of Rondout, IL in a holding yard waiting for a window to operate to the Bensenville cutoff. Put down another track for Pete’s Sake between Rondout and the cutoff (yes there is room for that), why waste that fuel and employee time…understood it is expensive but the current practice makes railroads look penny wise and pound foolish to the public.
You have to work with the facilities you have - not the facilities you may want. Signalled track (before PTC) was going for $2M a mile (more if you had to secure right of way) - how much return on that investment will you get from the additional track? With the super size trains that are being operated by all carriers today - should they be held in the middle of commuter territory, blocking road crossings while waiting for yard space?
Not big change - big dollars. Rate divisions work against St.Louis, Memphis and New Orleans as alternate gateways between East & West. Just like in any other form of human activity - follow the money.
Essentially the railroad version of an Air Traffic Control Center/ tower.
“+1” [bow] Applies to way more scenarios and situations than this one, in many other businesses and facets of life. A former supervisor often analyzed and attributed (credibly, I think) a lot of bad relationships to a lack of ‘face time’, and often recommended it to prevent and resolve such difficulties.
Eastern and Western railroads have different measures, and will not negatively affect their indices to make their connection’s indices improve. Chicago needs some manner of flow control at times, and needs greater flexibility in routing trains thru Chicago. But CSX won’t hold a train at Willard because of congestion on the UP, and vice-versa.Ashland Av. is not really a good place for unit train interchanges between UP and NS, for example. But neither road wants to pay the
Ashland Av. is not really a good place for unit train interchanges between UP and NS, for example. But neither road wants to pay the switch charge for operating their run-thru trains on IHB or BRC. The Chicago Op Center can’t fix that.
Transcontinental mergers would certainly help, as they eliminate the ‘divisions’ issue. But that may be impossible – for now.
The CIROC does not get people “face to face”. It is one person sitting in the CIROC office, mediating any Chicago Terminal disagreements over the phone with the involved carriers. They are located in the Metra Operation Center, no freight carriers are located in that building. The CIROC has no power, if railroads can’t or won’t take the train, they won’t. The CIROC can not force a train on a railroad.
The CIROC has done one good thing so far, they have mergerd the railroad carriers CADS screens into one. Now one can see just about everything going on in the city. &n
The positions you speak of abolishing would be General Managers and Superintendents. They have certain performance measures, such as running trains on schedules. A Superintendent overseeing Clinton IA isn’t going to hold a train there for later delivery to CSX, without receiving some manner of waiver on his schedule performance. And, last I looked, there weren’t any ‘asterisks’ on Division managers’ performance measures. So until that occurs, the likelihood of cooperation during stressed periods is very low.
