Finally getting my Westside Brass SP Daylight 4449 loco set up for DCC.
I’d like to the chuffs and things times right with the sound and the Loksound manual mentions a magnet and sensor combo. I know they were called chuff sensors at one point.
Loksound mentions a Hall IC setup…but I can’t find any of the sensors at all…anywhere. Am I maybe just looking up the wrong term or something? Or do they just not offer the sensors anymore?
In one of my early Tsunami steam decoder installs I used a bronze wire that contacted a square cam lobe on one of the driving axles.
Does your Westside engine have one?
Out of dozens of later installs I have not used an external sensor. Most of the recent decoders have a pretty decent chuff-timing adjustment that can be fine-tuned to give you good results.
BLI uses a reed switch reading a magnet on the flywheel. They are prone to failure as the mechanical contacts wear out after time. I have heard of some fellows gluing tiny magnets on the inside of drivers but this seems like too much hassle for me.
I would strongly advise you to simplify your train modification the way Ed does it. I do it the same way he does. I use the CV for chuff rate. I have a number of BLI engines produced since maybe 2010, and they have the chuff sensor mechanism. I read posts in forums about them breaking all the time, and not just BLI’s versions. So, I use the chuff rate CV setting built into all modern steam decoders. If you set your speed to about 15 or 20 mph, and then adjust the CV value to get the correct rate for the speed, you’ll find that it will be quite accurate over a range of speeds. Very reliable, just as realistic, and not prone to quitting suddenly and requiring you to open things up and do repairs.
Another advantage of using the CV adjustments, in addition to what Selector points out, is that when your locomotive is running at higher speeds the exhaust “chuff” can take on an annoying pulsating sound.
By using the CV settings you can slightly reduce the “high end” so there is more of a distinctive exhaust rather than a buzzing drone sound. Your ears and eyes can’t count the wheel revolutions too easily at that speed anyway.
I sorely wish Broadway had a way to override the reed switch. It is time they did away with that anachronism.
