Several of the classic Atlas HO layouts, as included in books such as “Blueprints for Atlas Snap-Track HO Layouts,” will incorporate one or two small sections of 15" radius track. I don’t think I’ve ever even seen 15" track, let alone used any.
I’m curious how trains perform on these layouts. Are the sections so brief that they do not hinder the operations? Is it easy to modify the layouts to avoid the 15"" sections? (I realize you may need a larger space with this option.)
I haven’t seen R15" curves in a while but it does exist. The minimum radii for most HO locomotives is either R18" or R22". Some smaller steam and diesel switchers though could handle curves as low as R15".
IIRC, the majority of layouts in those Atlas track plan books would be considered “spaghetti bowls”; trying to cram as much track as possible in a certain footprint. I always try to go as large a radii as possible and keep the track plan simple. It looks more realistic that way.
At the time the plans were published, Atlas sold 15 inch radius sectional track. I don’t know if they still do.
Long cars will not roll well if coupled in long cuts. I would keep by loco choices to 4 axle diesels and steamers with no more than six drivers. A 0-8-0 or 2-8-0 might work depending upon the manufacturer.
A couple of sections would generally still cause problems, although not as much stringlining of long cars as would an enitre 15 inch radius loop.
In my first layout, I used Atlas 15" radius curves on an industrial siding. Only 40’ cars and switchers went there. It worked fine.
As a bit of further information, a real UP SW10 could take a 15" equivalent curve, without train. An early Baldwin could best that, at 7" equivalent. And 16 1/2 WITH train.
It doesn’t matter how short the section of track is, if it is tighter than the minimum radius for a locomotive it will cause a derailment.
You definitely need to alter the track plan to 18 inch curves but it would depend on the actual track plan to say if it would be easy. Even 18 inch curves are too tight for longer cars and locomotives but 4 axle diesels and cars 60 feet and under should be fine.
Smaller equipment will have no problem. At the time of those plans though, many HO cars had talgo trucks with the couplers mounted ont he trucks, not the car body. This enabled them to at least be pulled through some very charp curves. In the early days of HO, 18" was the luxury radius, 15" was fairly normal and common. And the most popular locos were the Mantua 0-4-0 camelback, or the Varney 0-4-0T “Little Joe” Docksider. Either of those could easily negotiate an even smaller than 15" radius curve. Remember, at the tiem there was also Lionel, negitating 27" DIAMETER curves - 13.5" radius - an that was more or less O scale!
I have built a couple of Atlas layouts which specified 15" radius curves. The best one was the famous Morgan Valley RR. The 15" curves were on spurs, not the mainline, so it worked fine with slow switching using an Atlas Alco S4, and 40’ cars. 50’ cars did not work. Later I modified the layout design to use 18" curves because I wanted to use 50’ boxcars for an industry. The other Atlas layout I built was the double-loop “up and over” using a riser set and girder bridges. The plan uses 2 15" curves on two spurs. Right from the start I knew I wanted 18" curves, so I had to modify the plan by shifting the bridge pier locations.
In summary, yes Atlas 15" curves are still sold, and yes they do work, but you have to accept using diesel switcher locos and 40’ or shorter cars at slow speeds.
According to the Walthers website, Atlas and Bachmann (EZ Track) still make 15"R HO track sections. Kato makes track with 16-7/8" radius; I believe one of the European HO manufacturers makes 14"R track.
Thanks all for the replies. I am considering doing the Up and Over in 4’ x 6’, but on a 5’ x 7’ table to allow for more scenery along the perimeter. It sounds like I can modify the 15" sections on the spurs, and I may move the one that goes under the bridge to another location.
I run all mid-century trains, so I’m sure they will have no trouble around the 18" radius.
By the way, Atlas sells all of these older layouts as packages, with a code 83 or code 100 option.
I was surprised to see that Atlas is still selling 15" radius snap track (in fact it is currently on sale at Walthers). And I sure remember when you’d see plenty of layouts, even some ambitious ones, that had at least some 15" radius track - in an era which emphasized appropriate rolling stock such as an SW switcher or F7, 40’ freight cars, shorty passenger cars with talgo type trucks, and so on.
Speaking of appropriate rolling stock, some of the big AHM/Rivarossi articulateds were recommended were advertised as being able to run on 18" radius, and more than a few guys learned that they could even handle Atlas 15" radius curves. And in the article “The Mostest Track in the Leastest Space” in the January 1965 MR, Eugene Platt wrote how his big brass Akane 2-8-8-4, rated at 20" radius, took his 18" radius curves with ease. One photo in the article shows at least 16 brass locomotives of various sizes, but some quite large, on his 4x6 layout. It has to be seen to be believed.
If you expand it to 5x7, you’ll have reach issues to the middle, but also you can probably repalce all the 18" radius with 22" and the 15" with 18". And still add some extra straights to make it wider.
You should have no problems with engines and cars from that era. Just remember nothing longer then a 2-8-0 or 4-6-0 or no diesel longer then a 6 axle SD7/9 or Alco RSD 4/5. These engines look at home on 18" curves.
Yes, 15-inch radius sectional track is still available- -in code 100 and 83 from Atlas. Be it on back order status from their website.
On my pike I have asymmetrical curves of sectional track. Two are 18- to 22-inch while the others are 15- to 18-inch curves.
I could have used flex track but for the expedience of time; read I’m lazy, I went with sectional track.
With these tight curves I only run four-axle or smaller diesels and 0-6-0 or 0-4-0 steamers.
I also have sidings and a Wye made up of PECO #2 turnouts. All the GP’s have no problem negotiating these.
The coal drags are 12 to 24 cars long of vintage Tyco 34-foot operating hoppers, upgraded with body mounted couplers and new trucks.
A 4 unit set of GP40’s with 24 of these cars negotiate the loading siding made up of #2 PECOs.
The center piece of my layout is a spiral trestle made up entirely of 15-inch sectional track.
One modification that has been discussed on other posts is using longer shank couplers on locomotives to negotiate the smaller curves and/or turnouts.
With few exceptions I use Kadee medium-shank center-set couplers with no problems. The exceptions are due to conversion constraints.
One M.O.W. 60’ flat car uses the same couplers as the rest of the rolling stock with no problems negotiating the cross-over made with Atlas Snap Switches.
I tried an SD locomotive. It worked but looked awkward on the tighter curves.
Yes, 15" radius curves are still sold. back in the 1960s when I started out, they were quite commonly used, by people with space limitations, and Interurban Modelers. Back then, 24" radius was considered a broad curve.
FWIW, there were numerous tight radius industrial sidings on the prototype railroads at the same time. Very little freight equiment exceeded 50’ in length.
Today, most of these obsolete sidings are gone, along with the 40’ cars that used them, however, if one was modeling Urban Industrial Lines in the 1960s or earlier, 15" radius curved sections and 18" radius “Snap switches” are quite useful, in certain applications. Just don’t expect your favorite SD70 to run over them.
I have a return circle which has about 4 different 1/2 sections of 15 in radius spaced out between 18 inch radius full pieces. My Bachmann Spectrum 2-8-0’s have not had any problems in that area.
