Okay I goofed a little. Got some paint and other scenery plaster on the inside of the curved turnout and it now sporadically makes contact when the switch is thrown. I cleaned it with a bright boy, but you can only put so much pressure on it without bending the fragile thin rail. What’s the best way to ensure contact?
Been there done that. I tipped over the bottle of ballast cement on a Peco one time. Filled the whole point area with the mixture that glued the points solid.
Under the points on the Pecos there are little contacts that hit the bottom of the points when thrown. A small stiff bristled paint brush with some rubbing alcohol should clean them up with a little elbow grease. I also scrape the back of the points and inside of the stock rails with a #11 blade.
If you want to get a good electrical contact, a burnishing tool, or welding tip cleaners may also help. You will want to be careful, but if you can’t get things clean with a cleaning solution, these may work well. The burnishing tool is a small flat piece of metal with a very fine abrasive on it. They are available from Stanley’s website for less than $3.00. The welding tip cleaners are very fine wires with an abrasive on them. The last set of welding tip cleaners I picked up was from Harbor Freight two or three years ago. they were less than $5.00.
The most important part is to be very gentle with whatever method you use so that you don’t turn your switch / turnout into a pretzel. Don’t ask me how I know that!!
try using cotton buds (on small plastic tubes, as used for cleaning out your ears) and a solvent such as white spirit, peco plastic will stand up okay.
