Picked up over 60 pieces of Lionel post-war track. Looks like they need a good cleaning. Some have some rust on the sides of the rails but none on the top. Besides the usual track cleaners by Lionel and MTH, what do you guys recommend to clean them up and get rid of the rust?
The best remedy for dirty tracks that have been sittin unused is very fine sand paper or emery paper. If you are talkin regular scheduled maintenance, I HIGHLY recommend trying (and using) acne pads. The combination of the textured “cloth” pad and the alcohol mixture eats through any amount of accumulated gunk from average runnin.
How do you suggest attacking the oxidation on the sides of the rails and the rust. The rust isn’t the pitted type, just enough to want to make you remove it.
Scotchbrite pads are good for getting rid of light rust without doing too much damage to the tinplating.
While it’s true that you shouldn’t use sandpaper on fresh tinplate track, if it’s heavily rusted the tinplating is shot anyway so sanding it won’t do any harm. If your track has heavy rust on it and you want to use it anyway, go ahead and sand away.
For normal wet track cleaning, I like to use straight naptha, aka Ronsonal lighter fluid. It’s a great solvent that will evaporate quickly and completely, thus having no risk of harming your traction tires. Just be sure it’s all completely evaported(10-15 minutes should be safe) before you try to run anything-do otherwise and you’ll find what it literally means to fire up your layout.
Thanks guys, sounds like a small doable project. I took some a scotchbright pad to a couple of pieces and with some rubbing the grime and oxidation seems to come off. Tomorrow I’ll try it on some rust and see what happens. What about something like NOXON for the rust or that chrome posish for car bumpers (when cars had chrome bumpers) for the rust?
I seem to recall hearing that sandpaper was a huge no-no also as it related to chipping up metal particles, which your engines would then digest.
As for rust, keep in mind the critical area is the top of the rails. I have taken to trying to “weather” the sides of the rails using watered down burnt umber to give a weathered look.
As for cleaning, I had good luck with WD-40, I also understand isopropyl works well, but have not tried it.
A Scotchbrite green kitchen pad works very well for removing rust and oxidation from track. It leaves it looking clean and shiny. Very good at removing the rust, too.
I use 90% isopropyl alcohol and a paper towel to clean my track. The alcohol cleans the track extremely well, removing all traces of blackness and builtup gunk. It also dries almost immediately, and to be honest, I’ve used it while trains are running with no ill effects.
Frank’s point of view never occurred to me. The “weathered look” might not be so bad. Since none of the rust is on top then a good cleaning is in order. So now armed with all of your responses I’m on a mission. The track purchase may not have been a bad idea after all. And now I have several alternative cleaners that might be cheaper than buying the Lionel or MTH products. Thanks guys!
Use to have old layout in basement. Would get humid during the summer [due to airhandler being right at the layout]. Use wet/dry very fine sandpaper with fine results. Used the same thing when I got track out of storage 2 1/2 years ago. Some of the guys here are using that same track. You don’t rub the “heck” out of it, just remove the surface rust.
When I use sandpaper I use 600 grit and it’s just coarse enough to get the bad spots off and once the paper “Loads” up with the metal it actually starts to burnish and leaves a very smooth shiney finish. Still I agree sandpaper should be used as a last resort. When solvents can be used to clean your track use those.
I use alcohol on a scotchbrite. Put a rag under the scotchbrite as the alcohol may soak through and drip. After a rub down with the alcohol on scotchbrite a wipe with the drip rag and you are set to go. Cheap easy and works.
