What are the drums on top of these GP9s, mufflers ?
Did other railroads have these ?
I don’t know Dale but my guess would be some sort of spark arrestor. Didn’t Milw have problems with locos starting fires and run speeders a couple miles behind freights to spot / extinguish them?
We had these spark arrestors on all of the roots blower engines including the F’s.
Randy
Thanks Randy. (and Chad)
We(CN) have them on a lot of our GP9’s as well.
Was this only a problem with roots blower equipped engines? How common are sparks from a diesel locomotive?
Usually a problem with any non-turbocharged locomotive.
On a turbocharged diesel engine the turbo catches the sparks plus the exhaust is hotter and burns the carbon out before it leaves the stack. The spark arrestor was a great device that caught most of the sparks and kept the trees from going up in flames. The best flame display I ever saw was a SD-40 that had a blown turbo and lets say if you wanted to read you had all the light you needed.
