I just bought the Clean Mahine and was wondering if anyone else is having a problem pushing this beast around the layout. I have a Proto 2000 GP9 and it cant push it by itself. I think its the spring tension on the pad assy. I am able to MU my SW8 with the GP9 and get it to move around the track. Going up grades it still has trouble. Any help would be appreaciated.
I have a CMX Track Cleaner. They work great. Your PK2 unit does not have enough weight on the rails to push the track cleaner. I run mine with two PK2 GP30s with no problem. If you MU two locomotives together you should be OK.
Glad I’m not the only one. I thought I was raising wimpy little girlie-engines, ja?
I have subways, and the above-ground motive power won’t fit in the tunnels, so I have to MU together 2 subway engines to push my CMX around. I was thinking that MU’d subways in the modelling world probably are kind of unique.
The only time I have had the similar issue with wheel spin is when going back over track that was just recently cleaned. I pull the CMX track cleaning car and a John Allen slider car behind my loco and they seem to work fine on track that has not been recently cleaned.
My problems have occurred when using something like a Bachmann spectrum 2-10-2 up a 2% grade. On flat ground I think most normal engines can do it. Ofcourse my 2% hill is also on a 36" radius curve.
Yep, the car works great, but you really need 2 locos, e.g. 2 GP35’s, etc. or 1 Proto 2000. They are some of the heaviest diesel locos I have found. Try consisting with the cleaning car between the locos, and then switch their positions. The trailing loco’s wheels get cleaned at the same time as the track.
What are all of you using as a cleaning solution? I have only used lacquer thinner in mine and my BLI SW2 easily pulls or pushes it around 18" radius curves. Maybe isopropyl alcohol has greater friction?
I have used acetone. The odor was not bad at all. I would like to know if isopropyl alcohol is as effective, it’s probably less harmful in the long run.
