CMX track cleaner
Yes you’re right
I’m trying to avoid punching a hole in a speaker with a lost track spike
forgive me as I have never seen this unit before, is it as heavy as it looks?..is that the appeal?
it appears to do a great job of cleaning…is it worth the $$?
  1. Yes
  2. Well worth the $
[#ditto]
Tilden
I unboxed and installed the cloth to the pad of the CMX car, cleaned out the holding tank and filled it up with some cleaning solution. Then I ran it along with my John Allen slider car and cleaned up just about the entire lower deck tracks on the layout in about 30-40 minutes time.
The CMX track cleaning car is worth every penny! Not sure how much it weights, but it is heavy for it’s size and makes for a steady cleaning too.
Got mine in the mail today, my christmas present to me arrived on x-mas eve. How fitting.
It appears to be a very well built product with good instructions and reviews. The instructions state that Acetone and nail polish remover are recommended, all things considered. My wife has plenty of the polish remover, and I’m curious if anyone has used that and had good results. Or, are the more industrial type solvents better ???
Thanks, Joel
Merry Christmas, Guys!
To answer your question, the CMX machine is very heavy but that’s because the cleaning pad mount has springs in each corner which push it down on the track. The machine needs the heavy weight to counteract the springs and that’s good, because it’s like you pressing down a pad with your hands. If the machine was lighter, it wouldn’t rub the rails as clean as it does.
Someone asked if the cleaning pad has a problem with frogs and points. I’ve been using my CMX machine for several years and out of my 75 turnouts on the layout, only one had points which caught the machine’s pad and I had to replace the turnout. My thinking is that the turnout was the problem, not the cleaning machine, especially because the other 74 turnouts have never had a problem.
Hope this helps.
Mondo
Jim,
I too would have had some reservations about the use of the DW screen. The screen most likely wore rather quickly and now is burnishing the railhead instead of scratching. As long as it keeps working and the rails stay clean. That’s all that matters.
Here’s a bizzare question:
IS there a reccommended “speed” at which it’ll work? Fast enough to do a larger layout, but still do it efficently, and not so fast the pad just skims?
Your question is a good one…not “bizzare” at all. I looked at the enclosed instructions and they say the CMX cleaning machine works best at a speed of about 1-2 feet per second. You don’t want to run it much faster than that and too slow doesn’t work either. It’s real easy to get the right speed with a little practice.
Regarding the cost…it’s a little pricey at $99.00 but I have to say that it used to take me around 2 hours with a cloth wrapped around my finger and some cleaner and of course, it was next to impossible to get into my tunnels and hidden staging properly. Now, when guys are coming over, I whip out the CMX machine…a few times around the whole layout, both mainlines, and we’re good to go.
Hope this helps.
Mondo
By the way, one problem I’ve had is with the syringes that you get with the clean machine to fill the tank. The plunger kept coming apart inside the syringe. When I talked to Tony, he said after using the syringe, I should remove the plunger rather than leave it in the syringe. And, talk about service, he mailed me 2 new syringes at no cost…not even shipping.
Mondo
Sounds good. After a year or two’s worth of saving, and a layout, HO&N may just be getting a “weedwhacker tank”
This is why I come to the forums. I have the same issue with the plunger coming apart. I sent an email to their tech support this morning. I hope I get the same customer service that you did.
I don’t have one, but if you are using laquer thinner, it is probably softening the black plastic thing on the plunger.
If you know an anesthesiologist, or more likely a pregnant women, ask for one of their all glass epidural syringes. They are disposable and no plastic parts, but doctors think it is a little weird when a civilian asks for a syringe.
They are also good for drawing up solvent paints for your airbrush.
