Hi everyone!
I know that in code 83 you can find “concrete” ties, but I was wondering if in code 100 it also existed this option available with flex track.
Cheers
Hi everyone!
Cheers
Peco makes code 100 flex track with concrete ties. The best place I know of the purchase it is Cherry Creek Hobbies in Torrington, Wyoming.
Hi kokomo
As stated Peco do concrete sleepered flex track in code 100
I believe they may also now be doing concrete sleepered points as well sure I saw something about that in one of the UK magazines, so it’s worth asking about those as well.
regards John
Shinohara made Code 100 concrete tie track at one time. I don’t know about its present availability.
The one length I have has Japanese-pattern wasp-waisted ties.
Just an odd occurance with concrete ties: the CSX here in Knoxville, TN recently removed the concrete ties on a long section of track and replaced it with wood ties? The concrete ties were crumbling on the tops? Just an FYI, sorry if this is a little off topic.
-Bob
Same thing had happened here in Mass. the defective ones were replaced w/ other conc. While working @ a CSX facility in Ayer, MA, there were thousands of concrete ties stacked that were “junk”. I guess someone screwed up real bad, allowing them to be used, bad mix? improper curing? Well there’s a lot of solid fill or retaining wall.
