Having used up most of my track from my indoor line, outdoors, I plan to buy more track next spring. Up until now all I have used is LGB sectional track. How much is the physical height difference between Code 250 and 332? I do know it is 82 thousands of an inch…what does it look like side by side? If I used AMS code 250 rail and combined it with LGB turnouts, am I asking for trouble? Would I have to grind each joint where the 250 and 332 meet? I know you can get code 250 turnouts, is this the way to go? Thanks for your input! Later eh…Brian.
use the turnout but don’t grind! Use 332 railjoiner and put a shim under the 250 rail; or, simply solder the rails together so the surfaces of rails are even with each other and insides of rails line up. Shim can be a sliver of plastic or metal or styrene.
I’ve seen that suggested before, even the styrene. Can’t solder plastic. Beating the joiner into place is…well…futile. The top of the base hits the joiners in the same place. Don’t try to re-invent the wheel when there are products out there designed to do the job.
There are 332-250 rail clamps (I have a set here), plus at least Llagas makes cast “blenders”, about 1.5" long cast rail pieces.
You look at photos in the mag of folks who have scratchbuilt or super-detailed or whatever, and it’s on 332, I just turn the page.
Why bother to do all that upgrade and run it on 9-inch rails?
Outdoors, mainline is 250 and branches are 215 on the CCRy. I used all my old brass 332 in the shed.
It makes a world of difference in the appearance of the railroad, and in photographs.
Of course, since some think I don’t even have a railroad and have only been at this for two months, you can take that advice as you see fit.
Once again…thanks for all the input. TOC…glad to see your sense of humour is alive and well! I have not actually seen 250 rail hence the questions. We are planning a trip to the west coast come springtime. A dealer there sells AMS by the box. My indoor line is all narrow gauge. The turnouts will need to be tight since the largest space from the wall is only 24". I may even handlay with the LLGAS turnouts. We’ll talk later about a new trackplan! Later eh…Brian.
There are a number of good reasons to use your 332 rails, such as in a tunnel where it won’t be seen or something similar. Llagas creek, http://www.llagastrack.com/index.html , is the place to go for what you are talking about.
I also agree that the smaller rail looks better. This is true in any model scale, it just “looks right”. I use 332 for the simple fact of budget as well as I don’t really care a great deal about having my track look prototypical. I did do a great deal of research on the Llagas track, and from what I determined is that it’s the best way to go if you want to handlay or use the flex. Price wise it was not much cheaper than the Aristo-Craft and in the end I decided that the work involved in using handlay from Llagas was not the best for me. Later on when I do another rebuild (in 4 or 5 years) I will certainly use the Llagas track. In the mean time I’ve been sneaking in some orders for rail and ties (shhhh, don’t tell the wife!)
The non-existant 1400’ of CCRy is all 250 and 215 aluminum outdoors.
I started with ME, will never make that mistake again. Not enough UV protection in the ties. They “sparkle” in the sunlight and are the color of a 20-year-old Hershey bar.
All but two horrible hand-built turnouts outdoors are Llagas.
I have an “in” with Llagas…
Had I known about Llagas and 215 when I started it would ALL be Llagas.
The trouble with putting different sized rail like in tunnels is you have to adapt both sides. And, the tie height…by the time you add in the thicker 332 ties and the higher rail, you have to shim…
I have personally never considerd using 250 myself and i have only ever seen one railway with 250 and i can tell you i was very impressed with how realistic it looks. In fact it made a terrific difference.
However i believe you get more derailments on 250 and it is more expensive and harder to get, you cannot get the accessories that you have with 332,.
So if you really need realism and you are prepared to go the tough metres then why not.
That’s right Crumudgeon. My Bach 2-8-0 will derail on my LGB 332 rail, but I have no problem on your 250/215 rail. Iandor, it is sad, sad, sad that you believe that trains derail on 250 rail.
To be 100% truthful, trains derail on any kind of track sooner or later, model or full sized. The quality of track and wheel flanges, among other factors like wheel spacing, trueness and side to side flexion, with properly weighted rolling stock has more to do with reliable tracking than the code of the track itself. It’s wrong to speak in absolutes without comparative data to support one position or another.
I run 332 and I only have a derailment when something falls on the track or the train snags a piece of vegetation or small animal. Now does that mean all 332 track is derailment free? Of course not. Not any more than it means that 250/215 has a greater or less derailment rate. I feel confident that TOC’s track is laid with the utmost of care and accuracy so naturally he would have a very tiny percentile of derailments. Knowing that TOC’s 250 is derailment free and my 332 is derailment free, can we now assume all railroads using those codes will be derailment free? I have no way to answer that with enough certainty to make a blanket statement that all of one type of track is prone to derailments or not.
It’s the quality and care put into the entire railroad as a composite unit that makes it derailment free, not the code of track used.
Interestingly…in this case the 250 rail is less cost wise than the LGB. It comes in five foot lengths. I believe Kevin Strong used the very same track on his latest project. Looks like I will keep it all 250 for this indoor project. I kept robbing track from it as I expanded my outdoor line, which is all LGB. I’ll get Vic. involved with the track plan. He has a great way of making awesome use of tiny space. Outdoors I mainly just let em’ go. Indoors I plan to have lots of interaction. Thanks again for all the input everyone. Later eh…Brian.
The size of the rail has little to nothing to do with derailments, unless your flanges are so large that they’re literally bouncing off the spikes. I honestly don’t recall ever seeing that happen on all but the smallest rail sizes (code 197 and smaller). I’ve seen even LGB’s oversized flanges run flawlessly on code 215 rail. I’ve never personally experienced a derailment that was the result of the size of the rail.
What causes most derailments (besides switches) is uneven track. As the track twists and dips, the wheels will ride up and over the rails. That’s a function of two things–equalization (or lack thereof) in the trucks, and flange depth. The deeper the flange, the more variation there can be in the track before the wheel slips over the top of the rail. That’s the one advantage of large flanges. The size of the rail has nothing to do with that.
The one advantage larger rail gives you is resistance to the occasional misstep. However, if you’ve got a firm foundation under your rails–either in the form of concrete or some mechanical structure or well-tamped ballast–then you shouldn’t have much of anything to worry about. While I don’t make a habit of walking on my rails, my code 250 withstands the more-than-occasional misstep. Even my old railroad back in Rochster–built with code 250 aluminum that was just floating in the ballast–stood up as well as my dad’s code 332 line does to the occasional foot on the rails.
You’re always going to have derailments. Twigs, rocks, and other things that go “bump” will find their way under the wheels of your trains. Larger rail does allow the smaller objects to be passed over uneventfully, but if the object is lying across the rail (as is the cause of nearly all of my non-switch-related derailments) then size doesn’t matter.
My advice is to go with what you’ve already spent your money on. If you’ve got boxes and boxes of code 332 track, then go with th
Ok, now I am mainly screwed up… was told back in 04’ A-C 250 brass rail and LGB trunouts but relpace the LGB trunout motor. Is this wrong? Flanges should work well if not “high balling!” [8]
By “A-C” do you mean AMS or Aristocraft? The latter doesn’t make code 250 rail, but the AMS stuff was just announced in waining months of '04. I don’t know if anyone actually had it in the ground before '05.
I started using code 250 because I preferred the smaller size and more scale look. I chose Llagas Creek Aluminum because it was, frankly, all I could afford. I’ve installed four Llagas Creek #6 and #4 switches I built up from kits. I cut my own ties from redwood fence boards, and have powered the switches with Del Air motors. (Still working on that part)
<> The only downside of code 250 is that it’s not as robust as 332, so if you’ve got large critters, it will bend and deflect. If you use track power, know that joiners are the weakest link. The stainless steel ones I got from LC were worthless after about six months. I switched to Hillman clamps which hold together well, but had some problem with non-conductive corrosion. Fixed that by wrapping the rail with aluminum foil before tightening the brass clamps!
<> Derail doesn’t seem to be an issue – even with the spiked track. On the other hand, I don’t have any LGB locos.
My advice? Listen, then see some layouts with the various sizes and metals of track. Ask questions. Listen to the answers. Then make up your own mind. Finally, slip on a flack jacket, as someone is sure to challenge your decision. But remember – it’s YOUR railroad.
I have never actually seen many derailments on 250 myself but i have read in text books it is a problem with oversized flanges. But i have only ever seen one 250 layout and it was a very good layout overall.
I do not believe i could get 250 track for less than our club rail which is the normal size. I have alsonever see adds for 250 sets of points of which i use a fair foe of.
