Colors!!!
I bought a Woodland Scenics Rock Coloring Kit after Christmas and today I opened it up and tried to color my tunnel portals:
I found out that Sculptamold doesn’t color the same as Hydrocal [oops] !
This is what I wanted to get it to look like:
http://www.railpictures.net/viewphoto.php?id=161089&PHPSESSID=512d14ab94ca983877f641100ee5f7c4
Not quite there yet!
I started by spraying both with water, soaking them good.
I mixed a lot of water with some of the paint from the kit and mixed it up.
I used the brush that was included to dab it on and thats what I got.
What colors should I use to get it to the gray:
How about for the rocks, should I mix less, more, what???
Where would you think the rocks came from if they were that color???
Make a some “sample” rocks from each material, then experiment with different mixes of color on each, may take a few tries to get what you want, but you will have several choices.
Good luck.
