Common ground
I’ve proably asked this before? I’m using a K W to run two tracks.Can I use the same common ground for both tracks,but using two different postive leads
Boneheadbassboy
Just 8 blocks from the Old A.C.&Y tracks
(W&L.E.)
Yes.
John is right, of course. I hope you don’t mind if I point out that the variable voltages out of the transformer are AC, not DC, and therefore neither positive nor negative, or perhaps better, alternately both positive and negative.
Thanks for the help
Boneheadbassboy
