Commuter trains to Milwaukee. COULD IT WORK?
Right now Milwaukee Union Station is underused. Milwaukee want’s some form of commuter railroad and there are homes scattered along Lake michigan…right around the old CNW passenger line! it’s be hard to get a second track to go all the way but the line could run on a weekday schedule similar to the North Central Service (http://metrarail.com/metra/en/home/maps_schedules/metra_system_map/ncs/schedule.full.html) people hate to drive in gridlock on 94 and over time, the company could expand onto the CP line west out to Waukesha and Oconomowok and north to Sheboygan, relieving the stress of going to work in stop and go.
Given your state’s current political climate, you’d have to organize a local/regional transportation authority, like Chicagoland’s RTA, which is the taxing body over Metra.
Here you go:
http://www.jsonline.com/blogs/news/99767164.html
Current Wisconsin Rail Map:
http://www.dot.wisconsin.gov/localgov/docs/railmap.pdf
Let’s hope it can proceed.
It sounds like KRM is pointing in the wrong direction to drum up support, they are proposing an operation similar to Shore Line East between New Haven and New London CT. They might have better luck if it proposed as a suburban operation oriented to Milwaukee.
Another thought, more than a few years ago there was a proposal to reinstate the Milwaukee-Watertown operation but on a slightly more frequent schedule. David P Morgan took up this proposal in “News and Editorial Comment” and suggested that this proposal was unrealistic and that while commuter rail sounds nice, it’s not the solution for every situation and that an express bus schedule might have been more realistic in this case.
Typically, Metra under Pagano didn’t offer much hope for new services until the State told them to do it. Your governor and WisDOT, must got to the State of Illinois to work out something to direct Metra to participate.
Metra is authorized under State legislation. While it’s true that it is not permitted to operate in another state with the exception of Kenosha, that could be amended with a bi-state agreement for authority and cost sharing. Metra accepts the South Shore, so I’m sure a similar arrangement with Wisconsin wouldn’t be too difficult for just two lawyers to work out.
As for passenger volumes, Wisconsin riders would build as Illinois riders detrain. I doubt that the numbers of through riders would be significant from north of Kenosha to Chicago, particularly with the faster Hiawatha service throughout the day between Chicago and Milwaukee and could provide more frequent peak service that I’ve posted before.
Just as the Milwaukee District North and Union Pacific North share a substantial ridership in overlapping catchment areas, so might expanded Amtrak service with new stops in Gurnee, Lake Forest (West), and Lake-Cook, the last replacing Glenview. This could be relatively cheap to implement and augmented at a later date by the lakefront KRM line.
A separate KRM line would offer an opportunity to use the freight track from the wye at the Kenosha station to a new West Kenosha station on the Hiawatha line. The west station location is problematic and needs study.
If Wisconsin plays its cards right, it will insist on an agreement similar to the one that RTA concluded with NICTD.
Insist to whom?
My suggestion: The cities and towns of Kenosha, Recine, Milwaukee, Oconomowoc,. Waterntown, and Madison all get together and form a transit district. And then implement a diesel light rail line modeled on the New Jersey Transit Trenton - Camdon River Line, which just had its maximum speeds raised from 55 tp 60 mph, uses time sharing between freight railroad operations and the diesel light rail operations. The operation of such equpment is more economical than regular commuter or intercity trains, and more frequent service can be provided more econojmically. The infrastructure costs are about the same as normal-speed passenger rail. The lower speed as compared with high speed (althouhg upgrading the NJT Swiss Stadler equipment to 70 mph is easy) would be more than compensated by more frequent service. Close connections would be made both with Amtrak at Milwaukee and with Metra at Kenosha. The Stadler equpment would be modified for reclining seats and restrooms.
I don’t think that the agreement between Metra and NICTD would be a suitable model. Metra currently picks up 20% of South Shore’s operating subsidy based on the number of passenger trips wholly within Illinois (Hegewisch and west). Metra also owns seven or eight of South Shore’s MU cars for the same reason. Metra tickets are NOT honored on South Shore, even within Illinois.
The trackage rights agreement on IC between Kensington and Randolph street predates the RTA and goes back to 1926, when the IC suburban service was electrified and South Shore re-electrified. It precludes local haulage by South Shore north of Kensington.
I didn’t mean to suggest that KRM would have the same contract as NICTD; but that if the one could be worked out, so could the other.
While a Camden River Line operation might work over the UP with operating restrictions having little impact on limited freight service, the CP and Amtrak present a different situation where wholly new and separate tracks would be needed from Washington Street, Milwaukee to Watertown. This probably entails new bridges over the Menomonie River since the existing swing bridge allows no room for a parallel movable span in these tight quarters. Furthermore, there may be no space for additional tracks.
At the very least, new equipment would need to be FRA-compliant.
While frequent service may be desirable, this is something that needs to be studied with respect to potential higher train ridership with less frequent, 1/2-hour or greater, service that might favor train operation. The wild card is electrification. (See the new thread I started last night.)
I was envisioning hourly service, more frequent during the rush. Some early morning school trips for UofW students would start in Milwaukee for Madison, and a late evening opera-sports-concert-theater trip would run Kenosha-Milwaukee connecting with the last METRA from Chicago. The point is right now if I were living in Racine, say, and wanted an education, decent work, and some fun in life, my life would be centered on commuting to Chicago, where I could find part-time employment, classes at UofC or Northwestern in Evanston, and all the evening attractions one would want. I’d use by auto to and from the Kenosha station parking lot. But with the Kenosha-Milwaukee-Madison light rail, I would have possibilities both in Chicago and in Wisconsin. After breakfast, I could go from Racine to Milwaukee by light rail, work half a day, use light rail to attend two or three classes in Madison, return to Milwaukee to connect with Amtrak to Chicago (won’t do this daily, possibly twice a month) eat on the train (if there is no decent Amtrak food service I’d have my brown bag), attend a basketball game, concert, theatre, or opera, and then catch the last Metra back to Kenosha and the light rail to my auto at the Racine light rail station . The qualitiy of life in southern Wisconsin would be greatly improved. I could not do this scenereo by car, because the driving would be far too tiring to enjoy the evening show, and the time spent driving would not be useful for doing homework for the classes, etc.
The planning, choice of routes, etc. for high-speed Milwaukee - Madison should be applicable to a large extent with light rail. I think the type of vehicle does deserve some study. Possibly more flexibility with FRA-compliant equipment would be worth the additional first cost, weight, and fuel costs . Maybe rebuilt RDC’s as proving successful in Canada are the answer. Maybe the
Further thoughts: Wisconsin Commuter Rail is a better tag than Wisconsin Light Rail. With a Kenosha - Milwaukee - Madison goal, the money spent may not need to be returned to Washington, since Commuter Rail can be sold to the Administration as a step to HSR. (Remember how the intercity PRR electrification started!)
I think rebuilt Budd cars are the best and most economical way to go. And I know how such cars can easily be configured for one-man operation, with on-board fair collection like a bus, and with handicapped access, and emergency rear exit. Hints: all platforms for left-hand loading retaining current engineer-operator’s position over the right steps, and check the doors and stairs-elevators on the Breda MUNI-Metro cars in San Francisco. One-man operation would be restricted only to single-car operation.
Three distinct major commuter markets would be served by one line, in additon to connections with Amtrak, and all markets have employment and educational magnets.
If Wisconsin passenger train advocates read this, the act fast and present the program to the U of Wisconsin people, possibly starting with student affairs. If the University presents the idea to the Governor, then he can see it as a way of not having to refund money to the feds.
Hasn’t there been a effort to establish Kenosha-Milwaukee commuter service for some time? I remember reading about public hearings, etc. The whole thing stalled on the big question _ money. With the transit-hating Scott Walker as governor, all thinking and planning on this will be for naught for the next four years.
I don’t think Walker has demonstrated that he is transit-hating. I think he did use demogagary to get elected. However, I think the whole train to Madison idea was not sold to him or the people of Wisconsin as thoroughly as it might. It was sold as a step toward real high speed rail, which is sort of pie in the sky, and a quick way to get to Chicago and ultimately to the Twin Cities. Its great benefits to life in Southern Wisconsin were simply never mentioned.
Walker was specific in turning down High Speed Rail . Commuter rail may be another story and may well be worth trying. However, if there is no interest in puruing the matter here, with someone in Wisconsin actually picking up the ball, I certainly should let the matter drop . I don’t have the right mailing address to bother either the Goevernor or the University at this moment.
Frankly, if there is no expectation to fill a decent-size train at least in one direction, I’d guess ~350 riders, then the rationale for suburban rail seems pretty weak. If someone has a better feel for the break-point, jump in.
This isn’t a case of operating a required branchline service for a handful of riders at the least cost with an RDC or other self-propelled railcar. How many MARC or MBATA trains ran with a single RDC?
Service mo
Very true. The need and support just wasn’t apparent. A friend sent me an article from a Sierra Club newsletter, where it bragged about approximately 1000 people turning out at Save the Train rallies on Nov. 20 in seven cities (most of which are university towns). Wow!! 1000 people!! Talk about underwhelming. No wonder a demagogue like Walker could cancel the project with little fear of strong opposition.
Rather Slippery demographics were used, comparing rail to all trips in Southeast Wisconsin. When you look at all travel in the I-94 Corridor, especially in peak periods, rail travel achieves a degree of significance when you consider the billion it could take for road widening.
Again, hourly, not half-hourly, service during weekday off hours with single cars, hopefully one-man, and then trains with two or more crew members as required during rush hour. Commuter rail yes, but with the economical operation of diesel light rail. A transit district of the all the cities and towns between Kenosha and Madison including them. The approach for the Governor should be on the bsis of mostly local funding, the possibility of not having to return money already spent to the Federal Government, and low operating and subsidy costs compared with the first proposal, plus wider usefulness.
Would the students at UofW have used the HSR to go to Chicago? Not likely, given Amtrak fares. With this proposal people in a hurry, or want comfort, or wish to eat on the way, or all three can connect with Amtrak in Milwaukee while students looking for a bargain can connect with METRA at Kenosha. Any, without anyone volunteering to carry the idea further than just dreaming up negative comments here, I think I should pass on my suggestion to PTJ and see if they find it interesting.
It will just improve the quality of life in Southern Wisconsin . One thing the Governor has not considered is the loss of productive time when people are just spending their time driving. Tim on a train can be productive, reading, doing homework, polishing up a business report.
