I don’t know if i can help you anymore than ken already has but
you can start by clicking on this link
http://photobucket.com/
Then go toRegister now to open an account
http://photobucket.com/register.php?link=register_now
And follow the prompts to register
Once you’ve completed you’re account home page will display
and you will see a box labeled Browse
click on it and a small window will open showing your C drive
using this go to the file on your computer that has the photo you want to upload
double click on the photo and you’ll see the name of you picture in the small box
then click on upload
once the upload completes you’ll see a message “Upload competed”
if you page down you’ll see your photo on the page
there will be a small white box under it
place you mouse pointer on it and click
this will put a check mark in the box
Then page on down to the bottom of the page
and click on the box marked Generate HTML Code
this will automatically generate the code you need
on this page go down to the line of code that says
IMG images for message boards
high light the code by draging you mouse accross it
once the whole line is high lighted right click and click on copy
once you’ve copied that line Paste it into your message here
on the forum
When you are typing your post it will appear as
[IMG]http://i132.photobucket.com/albums/yada yada yada
but when you preview it the picture will appear
then go ahead and post it
There is no need to type anything else doing it this way
if you need more help
e-mail me @ Terryintexas7@aol.com
No i’m not a Guru but if i can do it so can you
