Con-Cor Zephyr lights
Just got a Zephyr and put a Digitrax DH123 in it. Understand that
the LED’s used for headlight and backup light need to have resistors
in series with them. Anyone know the values?
Hal
I think that the light board in this loco is already fitted with the correct resistors. There is an installtion guide on the TCS web site for this loco and it makes no mention of adding resistors.
http://www.tcsdcc.com/decoderpics/Con%20Cor%20Burlington%20Zephry/con_cor_burlington_zephry.htm
No additional wiring or resistors are necessary if you have a decoder that plugs into the Con-Cor circuit board’s socket, because that board already has the required resistors on it. Just plug the decoder in, program it, and run.
Thanks guys - seems to work OK.
Hal
