Hi all,
I’m in the process of redesigning my spare bedroom (about 11’ x 8’9") N scale layout. The existing layout runs fairly well, but I was just getting back into the hobby after a 2 decade break when I started it and there are a bunch of things that I didn’t design for from day-one that have been hodge-podged in after the fact. For example, I didn’t plan for any staging or operations at first, and I had to add on a narrow, stub-ended peninsula 2" below the main deck level which can only be reached by hidden, long, descenting ramps that each wrap 45% of the way around the room, one going clockwise and one going counterclockwise. The idea was, a train leaves staging on the peninsula, goes up one hidden ramp and joins the main, makes one lap on the main visible level (which passes over a duck-under across the door, also not ideal) doing work where needed, then leaves the main, descending the other hidden ramp back to staging. Like I said, it works and I can feed trains going northbound and southbound onto my single-track main, and technically it’s a twice-around-the-walls layout … but it isn’t ideal. My trains spend half their time on hidden track that also is all but impossible to reach as I build scenery above them, and my staging is very limited on length. And just to make things more convoluted, I added an inclining branch line which ascends around three of the walls to a mine area 2" above the main deck, which I used to help hide the overlapped trackwork where the ramps from staging join the main. So even my 1-scale mile mainline isn’t fully visible.
In short, although it didn’t seem like an issue when I was doing trackwork, now that I’m getting into scenery I’m discovering the issues caused by my afterthought changes to improve operational potential, plus I’m having a heck of a time making landscapes that look realistic.
So, with experience being a great teacher, I’ve decided to investigate a total redesign
