Daniel,
Your understanding is basically correct.
Hot gases go through all the tubes from the firebox to the smokebox, sucked through by the exhaust steam from the cylinders acting as a pump, reducing pressure in the smokebox.
The small tubes are called “tubes”, and in a locomotive without a superheater, all the tubes are like that.
The large tubes are called “flues”, and the superheater “elements” sit inside them.
There are basically two types of superheater, the Type A and the Type E.
The older Type A has a bigger flue, and each “element” reverses twice, so that there are four “pipes” in each flue so the steam goes down and back twice.
In the Type E the steam only goes down and back once, there are only two pipes making up the element in each flue, which is smaller in diameter. There are more flues and elements, so the total superheater is bigger.
The easy way to think about it is that the flues and tubes have the water on the outside, and the gases on the inside. The superheater elements have the steam on the inside and the hot gases on the outside.
The throttle is usually on the boiler side of the superheater. Steam in contact with the water in the boiler reaches “saturation” and can’t absorb any more energy. The steam in the superheater elements is no longer in contact with water, and can be heated further. This reduces condensation in the cylinders, and increases power by about 10% while improving fuel economy by up to 20%.
The superheater elements are connected to the boiler by the “header”, a big steel casting in the shape of a box (more or less), which is divided in two inside. One side is connected to the boiler, usually through the throttle valve. Each element is connected to both sides of the header, and the steam goes from the boiler side through the element, is heated and returns to the other side of the header which is connected to the cylinders.
The “superheater”
