I have a bunch (50+) surplus, 3-legged, bi-polar (R/G) LEDs that I want to use as dwarf indicators with my Tortoise machines. The Circuitron flyer only talks to 2-legged. Can anyone help with teh appropriate wiring for the 3-leeged vareity? I don’t want to have to go to a bi-polare power supply, if possible.
Appreciate any help - this is all kinda new to me.
You have to use the contacts on the Tortoise for these, they can’t be wired in series with the motor like you can with a 2-wire type. You’ll also need resistors for each one.
DO you know if they are common anode (+ common) or common cathode (- common)? You’ll need to know that to figure out exactly how to wire them. You can test it with a pwoer supply and resistor, hooking them up backwards won’t hurt the LED, but it won;t light up. Better to get that all squared away before you permanently install a bunch and find out you have ot all backwards.
Assuming common +, the + side of your power supply would go to the common terminal on each LED in your panel with a 1K resistor for each LED. The - from the power supply would go to one of the switch terminals on the tortoise, either pin 4 or 5. If using pin 4, then pins 2 and 3 woudl go to the other two legs of the LED. 1K is probably good if the LEDs are powered by 9-12V DC.
If they are - common on the LEDs, thent he power supply - would go to each LED via the resistor, and the + side of the power supply woudl go to the Tortoise pin 4 or 5. ANd if you use pin 5 instead of pin 4 for the indicators, then the LEDs would go to pins 6 and 7. Pin 4 is the common for the internal switch using pins 2 and 3, and pin 5 is the common for the switch using pins 6 and 7.
If the wrong color is on per turnout position, but your toggles are correct, swap the wires on the LED or at pins 2 and 3 of the Tortoise. If the wrong LED is on AND the toggles are wrong, flip the motor wires on the Tortoise, pins 1 and 8.
Where are you trying to post the picture from? You have to upload it to a picture host like Photobucket first, you can’t post pictures directly from your computer in here.
When you view your images, there is a box labeled “Direct Link”. You paste that in the box after clicking the media icon in the box here.
Don;t forget the resistor on the common lead of the LED, and also those wires on the toggle switch connecting the bottom left to top left and bottom right to top right - they need to cross, bottom left to top right, adn bottom right to top left. Otherwise nothign will happen when you flip the toggle.
If using one resistor in the common lead results in different intensity of the red and green LEDs use two resistors, one on the red and one on the green side. Adjust the value to suit.
