Is there a perferred method of hooking up an HO scale catenary system? I had thought weather to solder the catenary together at joints or to use superglue. I have a set of Viesmann catenary. I fear that it’s very complicated to connect the joints. I will greatly appreciate any suggestions.
The Viessmann catenary system does not require any soldering or gluing and I cannot recommend to do so, as it might buckle up due to temperature changes.
Thanks for your reply. If it does not require any soldering how the heck are you supposed to link the gaps and connect them? I am so glad I asked this question earlier.
Try this page for info on how to install Viessmann catenary:
http://www.ontracks.co.uk/library_guides/110_guide_viessmann_catenary.htm
Thanks for the link.
