I want to connect two main lines together using lionel 036 switches. What is the minimum distance between the two main lines in order to make this work? (Center rail to center rail). I will also need to have a short section of track in between the switches to isolate the loops electrically.
Best way to determine that is to put your short piece of track between the two switches and measure the distance as (1) we don’t know how short of a piece your using.
The smallest piece of fastrack that has the center rail cut is what I would use
I don’t use fastrack so I wouldn’t know I was just giving you a way to do it.
