I’m connecting some Arduino circuits using thin magnet wires. I want to be able to connect and disconnect the wires using some sort of plugs. These wires will be running under the layout.
I don’t want to solder these wires, since I may be connecting or disconnecting different wires.
Does anyone know of some good connectors for magnet wires?
The pin & socket that Mel showed is based on a NEM 652 which has a pin spacing of 2.54 MM. There is also a plug and socked based on the NEM 651 which has a pin spacing of 0.05 between the pins. Some DCC suppliers stock these in 40 pin single row headers which you can cut to a length you need. Much smaller than the 652.
I was wondering about the .05”/1.27mm header strips, have you tried any of them? I prefer the round pin .1”/2.54mm connectors mainly because you can easily swap the pins to make polarized connectors.
I do use the square pin (Arduino type) for structure lighting but really like the round pin for passenger car lighting. All of my structure lighting is incandescent so polarity isn’t important. I have cut over to LEDs in my passenger cars so polarity is important.
I have been kicking around getting some .05”/1.27mm headers and found a vender on eBay for the round pin but haven’t gone there yet.
Mel, that is all I use. The round pins & sockets. 1.27MM. IF I need to index- I use one pin for indexing. Cut off the pin and solder close the matching socket-
I received the .05” header strips yesterday, 10 days is very fast from China. I’m very impressed with the size. I was able to remove the pins for polarizing the connectors. The only things I don’t like are losing a pin for each cut and the price per pin is way up there, 4¢ per pin.
Thanks for the info! The tiny connectors will come in handy for automation projects. I think I’ll stick with the .1”/2.54mm headers for normal stuff.
