Connectors
I guess all those years building electronics projects makes soldering second nature to me. Our old train layouts, even though temporary for the holidays, always were soldered. And I just continued that as I built my own. In the DC days it was just one or two sets of feeders tied together to run back tot he block toggles, and some 3-conductor wire spliced in to extend the wires for snap-switches.
It’s even easier for DCC, with a pair of decent Klein or Ideal strippers, I can nick-free strip a bare spot in the bus wire, snip off the isualtion on the end of a feeder wire, and wrap it tight around the bare spot of the bus. Few seconds with the soldering gun - 150 watt type, keep the low power unit on the bench for decoder wires, it’s not usable here - and the wires are soldered on. I can’t remember the last time I dropped a blob of solder on myself working under the layout - that happens when you apply the solder to the tip of the gun instead of the joint like you are supposed to. Plus it’s easier these days - putting the layout up to reasonable viewing heights on the top means there’s that much more room underneath as well. I can sit normally under mine, no wierd hunched over positions. Which also means, unless I try to reach for a connection, there generally aren’t any body parts under the joint being soldered anyway.
If I were so inclined, I would only use the real 3M brand connectors, not the cheap knockoffs. But even for the relatively small layout I have now, the cost of the connectors and a proper set of pliers (even avoiding the official tool which is REALLY expensive) would exceed what I paid for a spool of solder and the soldering gun. Compounding the problem is the feeder solution I found, is about #22 wire, comes in two colors which match my bus wires - neither 3M nor the knockoffs have a connector which goes directly from my feeder to my bus, so I’d have to use TWO connectors at each feeder (and I have a lot of them - every turnout has 3 se
Soldering is cheapest way to go. If you want ti use IDC’s, use Scotchloks. Make sure they are sized properly for your line and tap wires. If not, don’t try to double the wire, etc. to compensate. Solder works on all sizes. If it drips while soldering overhead, that’s the extra wasted piece that wasn’t needed. It only hurts for a little while.[:(]
Martin Myers
The (only) advantage to the Scotch Locs is that it is insulation displacing: you can connect to your bus whire anytime, any place without problems. (Well LION had problems, but another story is that), LION solved problems by stripping all of the inuslation off of his bus wires before installing them. Clamp one end in a vice, take a knife to the insulation and it is GONE! A bus after all is supposed to be a bear wire to which you can connect anything.
Railroad of LION has three bus wires.
  1. GROUND
  2. +16 Volt Signal and Detetection power. (Also used for Aux Lighting)
and
  1. 600 volt DC Third Rail power. (OK it is realy +10.2 volts for the track power)
Starboard Rail gets the Power, Port Rail connects to Ground.
Photos forthcoming.
ROAR
