Consisting BLI AC6000 with Atlas Dash-8s w/ sounds
Has anyone tried to consist a Broadway Limited Imports AC6000 with sound to an Atlas Dash 8-40C/CW with sound? I was just curious if anything works out or if adjustments to the decoders must be made to compensate for different manufacturers.
Also, do the ditch lights flash on the AC6000 model?
Thanks in advance!
Which BLI AC6000 are you referring to? They made several versions. Paragon and Paragon 2 and also several versions of Blueline.
Pete
Either the Paragon or the Paragon 2. If you have information on both I would appreciate it if you would share :slight_smile:
First Neale forgot to welcome you. Welcome,
Here is the BLI site that has all the latest documentation.
http://www.broadway-limited.com/supportdocumentation.aspx
Paragon originally had QSI decoders. They should be very compatible with the Atlas that also uses QSI. Paragon 2 is brand new and uses BLIs own decoder. It has been getting good reviews but some complain about the turbo whine being to loud. As for consisting Paragon 2 with the Atlas I can not give you info for I do not own one. I am waiting for the I1sa to be available.
Pete
Thank you for the welcome! I’ve been lurking around here for awhile but I have had nothing to post! Thank you for the link. I’ll take a look at it.
If anyone else has any input on this feel free to share :slight_smile:
