YUP!! Piece of cake,After the Red line is in,the only problem,I see,is finding,the nut & bolt,detail…If you want it…You cut the Red line track,to create the crossing,just not all the way,through both rails…With one of the wider Dremel cut off disc’s…You will hear the clickty,clack,that way…
A lot of it depends on how detailed the crossing need to be and whether you are going to solder all the frogs together.
Personally I would do option #1. The toughest part will be getting all the curves in and parallel. The red tracks are straight lines, they are easy to cut. Plus if you put in the red line last, since its on top you could have a continuous running surface if you liked, but you’ll probably want to notch it to get the clickety clack going across the diamonds.
The other way would be to find the commercial crossings that best fit the angles and then trim them up close to the diamonds and connect all the curves with flex track. Might not be as pretty or the angles might differ from the pictures, but would be quicker.
No need to make the “dummy” tracks live because they would lead to nowhere on the Dream Layout.
On that section of the layout, only the red colored tracks would be live wired because that route leads to other parts of the layout whereas the unpowered tracks are simply there to reflect the prototype.
My one hesitation about Option 1 would be my questioned ability to cut out pieces of rail precisely so I don’t cause derailments when passing over the diamonds.
As far as commercial crossings are concerned, I might be able to find something close, but I worry about the cost, considering that I would need 20 of them.
But dummy tracks would not be a proper representation of the real thing! It would be sooo cool to have it all working as the prototype, with trains going thru the diamonds in all 4 directions!
I think you misunderstood Option 1. Except for guardrails the shortest piece of rail you have to use in Option 1 is 3 feet and that’s because you can’t buy longer rail. You could actually incorporate the guardrails into that and not cut any short pieces (although it wouldn’t be as prototypical looking.
Option 2 is the one that uses a gazillion little pieces of rail.
