Back when I first re-entered the hobby, the modular concept was really ramping up. Folks where constructing modules with all sorts of individual themes. One that came to my mind was a powerplant scene/module. I had written,…
The power plant subject came up on another thread just recently, and that is what prompted me to look back for this posting. I just don’t recall seeing a lot of good power plant scenes that might cover a broad era of their use.
As I mentioned before not a lot of young folks even know where and how our electrical power comes from/is generated. I wanted to create a whole scene with the older style coal plant (with coal piles sitting along side the delivery tracks). then perhaps some ongoing construction to a portion of that plant with turbines sections (peaking and otherwise) being added to the plant.
Then over the river bridges (source of cooling waters),… a nuclear plant under construction. I had (have) collected lots of various transformer delivery train cars, and lots of various style construction cranes This could be a pretty exciting scene to visit, particularly with today’s multiple flashing LED lights on construction equipment.
I began collecting lots of construction cranes. I seem to recall that a lot of them came from European sources, sold thru Walthers. I saw some modules at the Timonium show with multiple cranes involved in tall building construction, and one very impressive one with multiple tall fire fighting equipment/cra
Frankly, every mass produced model of a crane I have ever seen looks like garbage.
The best model crane I know of (it is actually a dragline), is the Classic Construction Models Manitowoc model 4600.
This one will set you back a couple grand.
I am so glad they never produced a model of a later 4600 with the dual Cummins diesel power, low cab, and Red & White paint… I would be a couple thousand dollars lighter in the checkbook if they did.
And a fine-looking strapping young lad on the real thing in 1995:
Not necessarily so, Walthers new lattice boom crane is a decent model, you can add a Sheepscot lattice boom to those Insleys made by Woodlands Scenics, or use the two kits offered by Sheepscot, they’re not bad models. I personally would steer clear of that lifelike crane, but to each his own.
Walthers scene master dragline kit,#949-11006, you’ll have to go to. Sheepcots web site for their offerings, I believe they have two cranes, plus the brass lattice boom kits(soldering is required), and check various web stores for the woodland scenic Insley crane, it comes as a back hoe. Oh, and custom finishing offers a cable operatored back hoe, check web sites also.mh
The cab is on the wrong side for an American (country not company, but true for American Crane too) crane/dragline except for Lima. Lima was the only one I know of with the operators cab on the left side of the house. This meant all the engines used in Limas had to be left hand rotation.
The house looks kind of like a Bucyress-Erie model 88, which could be rigged as either a shovel or dragline. Like I said, the cab is on the wrong side, and all the details are wrong…
That model looks nothing like any crane I have ever seen.
Maybe someone with more crane knowledge can offer better information about what this is supposed to represent.
It looks like they took the old “Steam Shovel” model and just tossed a boom and drag bucket onto it.
I guess if you wanted to make a sub-par Z scale model of a Lima 2400-B that model could be the starting point.
Unit and link belt and American have cabs on left side, I have a picture of a crane that Walthers is close to. The Walthers crane is a decent model though. The Kibri and Walthers look like Menck cranes.
This topic pretty much highlights the basic challenge of N Scale modelling: getting the latticework light enough and spidery enough. The thick heavy models currently available are very close to that dreaded toy-like appearance.
Please note that I am not whining because of the lack of N Scale stuff, even though it might appear I am. I’m always on the lookout for new avenues to explore, especially construction equipment and over-the-road trucks and trailers. This thread has helped a little.
Seems to me that while it’s great to keep the modeling bar high accepting reasonable facsimilies in our scenes is often part of the model railroading hobby. And ‘one man’s garbage is another man’s treasure.’
I like my Artitec tracked crane and glad to see Sheepscot products available at the Gandy Dancer Hobbies website.
Mike, Really dig your traveling gantry crane, I had the pleasure/displeasure of operating a smaller version that was track mounted and air-motor powered.
Smaller driveable or trailerable equipment (excavators, shovels, boom graders, cranes, etc) tends to have the cab on the left side.
Tracked draglines and boom cranes, except for Lima, and as far as I know have the cab on the right. Putting the cab on the left causes all kinds of engineering problems when you leave hydraulicly controlled cranes and go to braked drum operation. Lima uses left hand rotation diesel engines to get around the problems.
I suppose there would be other solutions, but I do not have any experience with them.
It amazes me how modelers that insist that locomotives must be accurate down to the headlight style and walkway tread will setlle for such low quality models of heavy equipment.
Peter, I enlarge your image and zoomed in on the tracks. Your work on the lower assembly is remarkable. Your finish really is an amazing accomplishment of capturing the look of a well used piece of heavy equipment.
