I think you are over thinking this. You need some sort of cross support everywhere to hold the longerons in place and parallel, so longer ones, and more of them, under the loop should support the foam just fine. That assumes reasonable sizing for these supports.
I think you are expecting the spline to require less support than it will require to be stable. Curved, straight, loop, whatever, I would expect the spline to need support every 2 feet more or less. And the relatively sharp curve you are planing will require more, you cannot expect to cantilever that curve very much, it will twist and sag.
I agree with Brent in that lap cuts in the blue/orange supports would keep things on the same plane.
IMO, the advantages of spline (a laminated beam really) is to make an extremely narrow yet rigid subroadbed for instances where you can’t have or don’t want a lot of support structure underneath.
Like a laminated beam home remodelers use to open up a space by eliminating the vertical supports for the ceiling.
You can do the same thing with traditional benchwork, as long as the horizontal supports are robust enough as to not sag towards the edge.
As depicted, the blue/orange grid structure looks very close to a traditional horizontal support structure for sheet plywood subroadbed. where there would be four legs in the middle of the peninsula where the blue/orna
Doughless
would that be less work and significantly better structurally than just attaching the cross piece to the side of the spline?
Doughless
i’m familiar with light-weight wing spar design and laminated beams when i built a garage
Doughless
As depicted, the blue/orange grid structure looks very close to a traditional horizontal support structure for sheet plywood subroadbed. where there would be four legs in the middle of the peninsula where the blue/ornage intersect.
this makes me wonder if such a lightweight structure would easily tip and if additional legs are needed farther out?
Doughless
Is the issue about avoiding sag from the middle supports to the edges, more so than scenery, and wanting to keep the entire structure light enough to discourage the sag?
not concerned about scenery which i believe shouldn’t be a problem.&
i’m working to get the first two layers glued together along the radius i want. i assume after that, 2 layers can be added at a time to the outside of the existing spline.
Greg, I would glue about 2’ and clamp being careful to make sure it was dead even with the other peace. Using a glue gun it set quickly and I proceeded to glue the rest. I would probably glue a couple of feet clamp and keep going. Once the first two strips are together nothing is going to change. If you get the first 2’ lined up a set the rest will line up automatically.
Fifteen years later it is still solid without any signs of delaminating. Remember to put a screw through every couple of feet in alternating directions. Drill a pilot hole or you will blow up the spline.
