I cleaned the axles on the tender of my steam locomotive and the performance was noticiably improved. I used a bright boy type eraser to do this and I wonder if that is the best thing to use and also if I should try to clean the copper ‘wipers’ also?
Jarrell
I sure would try if it was mine. You know how copper does. Just look at a penny. That ain’t how copper contacts outhg to be. Just my two cents.
Yes you should clean the wipers, but you must be very careful not to bend them or deform them - otherwise you will have very clean wipers that don’t do a darn thing because they don’t touch the axles anymore.
I wonder if there is a liquid cleaning agent that you can put on a Qtip and gently run between the wiper and the axles. It seems like that would be best instead of rubbing them with the bright boy. I know me… if I can deform them… I will.
Jarrell
Any one of the solution type (no rubbung) cleaners made for removing tarnish from silver will work.
Jarrell,
You need to watch out for some of these cleaning agents as they will remove the tarnish, but leave a non-conductive film. A pipe cleaner and alcohol is good to get in between the wiper and wheels of the loco and I usually clean the tender wiper with the same. If the tender wiper is in bad shape you need to remove the axles and clean it with something abrasive like a bright boy or even a burnishing tool. If you bend it, you can always form it back. Whatever it takes.
I wi***hey had used something other than copper for them, but we would probably have to pay $50 more for the loco.
REX
There’s a product called “Conducta Lube & Cleaner” by Aero Locomotive Works, http://www.aerocarlubricants.com/Trains/index.htm
E-Z Conductive Contact Lube & Cleaner By Bachmann, 160-99981 in the Walthers. Both can be used on the wipers.
Yep, if it has ‘made for model railroading’ on it, double the price!
Thanks Rex.
Jarrell
Thank you for the link, Chuck. I don’t know how the heck the wipers on the tender got dirty in such a short period of time, but they did. They’re not bad, but they do need cleaning.
Jarrell
