photos too small: Try using copy and paste to Microsoft Word, resize the page and use your mouse on a corner of the gif to resize it until the photo or schamatic begins to pixalize. The photos copy across fairly large without extra enlarging.
Here we’re looking at the back of the panel with the back frame removed. This view is nearly edge-on to the panel proper. I hadn’t started wiring it yet when I took this shot:
One of these days I’ll add a view of the wired side. It isn’t nearly as neat as the electrical engineer’s panel above, but it serves its purpose.
The switches are SPDT submini toggles from Digi-key. The panel is roughly the size of a sheet of letter paper - 8 1/2 X 11 inches.
Firstly I used a 18v power supply with a tap also at 9v. The 9v became a common and then 0v became -9v, and 18v became +9v.
I ran the common as a bus which all the switch machines then tapped into for one side of the power. The +9v and -9v then run to each toggle switch which are SPDT rocker switches.
I mounted these switches directly on the fascia in line with the turnout blades, I don’t bother with control panels as I use walkaround operation with DCC. If I have a crossover I wire them to a single switch which is in line with the closest turnout.
Having said all that - i’m planning a new layout. At this stage I’m planning to use Tortoises with NCE’s Switch-It which also has the ability to use push buttons which i’ll place on the fascia in a similar way to what I did before.
[:D][:D]No they are still shays and slow ,but can pull more,They don’t realy like to run tandom,They both have can motors,but not the same ones,They will work better togethor when I get twin can motors in them, Mike is 15years old and Ike is six months old.[^][^][:)]
JIM
The switches are sub-mini DPDTs (I said SPDTs earlier by mistake) from digi-key. I don’t have the catalog number right now - I’m halfway across country from home. But they’re about the cheapest small ones they had. The panel face is roughly 8 X 10 1/2, with the rest of the standard letter sized paper (8 1/2 X 11) hidden in the retaining grooves cut into the frame.
"Firstly I used a 18v power supply with a tap also at 9v. The 9v became a common and then 0v became -9v, and 18v became +9v.
I ran the common as a bus which all the switch machines then tapped into for one side of the power. The +9v and -9v then run to each toggle switch which are SPDT rocker switches."
Great Simple solution. I went to electronics school 25 years ago and forgot that simple answer. ( if you don’t use certain brain cells, then the grind of daily living throws out the older knowledge ) Great way with + - 12-16 V to throw Kato Unitrack Switches. Dave
I think it’s called split potential. I’ve also seen throttles built using a similar principle. I did it because the wiring on each switch was easier.
I’m defineitely no expert with electronics. I’ve done a few decoder installs including LED lighting and also built a throttle based of a adjustable voltage regulator.
