My layout doesn’t use DDC, but it’s interesting to me. Are there computer programs that let the operator run their layout from the computer? It should be simple to provide a computer interface to the DDC controls.
Just wondering.
Just wondering.
I’ve posted a similar question last week in the “Layout building” forum and you could look at the answers I received under “Model train automation”.
I also suggest you visit CTI electronics website which should give you a fair idea of what you’re asking for.They even have a free software for download,all you’ll need is the necessary hardware.
Don’t get confused by terminology. A DCC layout is not controlled by a computer. With DCC, a so-called “command station” contains computer microchips that superimpose a digital control signal onto the track power, but you still control the locomotive’s functions yourself. If you want to get a better idea of what DCC really is or does, try downloading a DCC manual from one of the manufacturers, who usually offer free documentation. For example, you can download the CVP Products’ Easy DCC operator’s manual from their Web site and read through it off-line with Acrobat Reader. This might give you a better idea about exactly what DCC is, and whether you would really like to convert your layout. When I wired the Cochise & Western Model Railroad Club’s 20x40 foot HO-scale layout as it was being built, I provided for both DCC and DC block control, so everyone would not have to go to the expense of installing decoders in their locomotives. Over the years, every member has switched most of their locomotives to DCC because it provides much better control than what can be achieved with DC block control.
Yes, but you must have a computer interface in addition to a command station.
I’ve wrote a program called ZugDCC (http://www.zugdcc.com) that operates the Lenz DCC system.
For hardware you need a Lenz Set90 or Set100 (the command station and a throttle),
and a LI101F computer interface. You may still see LI100F around but they cost a fair bit more then the newer LI101F (althought I think the LI100F looks nicer:)
If you want to be able to control turnouts you’ll also need stationary decoders like the LS100 and LS110.
And my software gives you 8 on screen throttle, turnout control, routing, decoder programing and a scale calculator.
There are opertion options out there, other brands, but this is what I use. And as far as I know, I’m the only DCC software writer actively involed in the train forums.
check http://www.lenz.com for the hardware.
I personally think that computer running is where DCC was about in 1985, a dedicated but growing minority of users. It is beginning to feel that computer running is beginning to gain momentum so you will definitely see more in the next few years and more.
I am planning for it myself, running Digitrax goodies, like the PM42, DBL16, transponding decoders etc. Its interesting planning for something you’re not quite sure of in terms of technology, but I am learning as well.
I suspect as more and more youth come into the hobby, they will be looking to run their trains (some of them) via computer. Where’s the youth when you need them?
