I recently purchased a used Spectrum Peter Witt trolley car which was ready to run for DCC & DC. To run it just on DC there was this little “dummy plug” as they called it which snapped into the decoder and removed the DCC plug.
Would there be a similar option for another engine I have that I believe was converted to DCC? It is a Walthers Trainline EMD F40Ph. I believe it was meant to be DC (which I thought I was buying at the time) but the person I bought it from had converted it.
A long winded way of saying I would like to run it on DC without ruining it.
Some very early “DCC equipped” Atlas engines had a six-pin plug that you had to move to change it from DC to activate the installed DCC decoder. But I don’t recall any other manufacturer doing that.
Engines that are not DDC-equipped from the factory often have a green light board with an eight-pin receptacle with a dummy plug in it. You remove the dummy plug to plug in a decoder. To change it back to DC-only, you would do the reverse.
Keep in mind virtually all decoders are “dual mode”, meaning you can run the engine on DC or DCC. Before doing anything else, try running the engine on DC and see what happens. It’s not going to hurt the decoder.
Note that there is a setting on the decoder that can essentially ‘turn off’ dual mode, so they only respond to DCC. Some DCC decoders seem to work better when they’re set to DCC only. If the decoder is set that way, it won’t do anything when you try it on DC - but again, it doesn’t harm the decoder.
If the loco is hard wired and the decoder is dual mode, it will not start the loco until the track voltage is about seven volts. The decoder will wake up at about five volts. The computer chip on the decoder runs at five volts.
Nature of the beast. If the DC option CV has been disabled by the previous user, it will not respond.
That’s only if it’s a sound decoder. A motor only decoder, so long as CV29 is configured to allow DC operation, doesn’t work like that. There’s maybe less than 2 volts needed to get power to the motor, same as a plain DC loco with constant lighting installed.
The sound decoders need a lot more voltage because they do need the computer ship to run, and the amplifier to have power, so you cna have sounds without the loco tearing down the track at warp speed. So the first 6 volts or so goes to just powering the electronics.
I was wondering what it would take to convert a proto 2000 engine from DCC back to DC. it is just the matter of unpluggint the decoder? Woulkd I need a dunny 8 pin plug, or is it more complicated?
Some didn’t have a plug, and you had to cut traces on the circuit board as part of the conversion, assuming it was left in place. With a larger decoder it may have been completely replaced by the decoder.
If the decoder is hard wired, just disconnect/remove it and wire the pickups directly to the motor.
If the decoder came pre-installed from the factory, they should work (as many do) on both DC and DCC. Why go thru work and effort to remove it if it already runs on DC? Even if you bought it used, and it runs on DC, just leave it alone…
First, try running it on DC. As has been noted, it should work on DC with no problems. Almost all after-market DCC decoders are “dual mode” meaning they work on DC or DCC just fine unless the previous owner adjusted the CV to not allow DC operation.
If you really want to remove the DCC decoder, you’ll need to either plug in the dummy plug (assuming it came from the factory with an eight-pin receptacle) or, if it’s a “hardwire” installation, you’ll need to get out your soldering iron and remove the 9-pin harness and wiring, and re-wire the engine for DC.
