Converting a DC layout to DCC
I am thinking that now is a good time to convert my layout over to DCC. I am running in DC as of now and would like some info on converting it to DCC, I have the layout up and running with #12 copper buss wires and smaller feeder wires every 2’ to 3’, the track is all ballasted and the scanery is all in place. I have a couple of reverse loops that work well. I am thinking along the line of Digitrax DCC system.
What all am I going to have to do to convert to DCC? When I built the layout I did what I knew to do for the future installation of DCC but not sure what is involved in the change-over.
I can get a Bauchmann DCC trainset at Hobby Lobby for around $100.00 with a 40% off coupon, this will give me a basic DCC system as well as a DCC diesel loco, this would get my feet wet with DCC a lot cheaper then the Digitax system as I would still have to convert my locos to DCC. Is this something that might be worth a try? I have read a lot about the DCC in the past couple of years, but have actually never seen or used one. Are the loco’s hard to program?
Thanks for any help. I might try to get something when I decide what I really want. Thanks Mike
Pretty much all you do is disconnect the power leads from your DC power pack and hook them to your DCC unit.
UH I mean, you don’t connect the DCC to the DC power pack, uh I mean you connect it to the track. The DCC I mean. You connect the DCC to the track. Disconnect the DC first. You get what I’m trying to say right?
To convert the layout, just connect the DCC power booster output to the wires that were connected to the DC power pack you have been using.
More misinformation. Drives me nuts…
Digitrax will run DC locomotives as well as DCC locomotives. Why waste your money on a system that you will throw away as soon as you see its limitations? I would spend the difference in money and get something worth while.
David B
I’d start out with the Zephyr or PowerCab, and put a decoder into one of my DC engines. Sot a little more, but you’ll keep it forever, so in the end it will cost less. The B-mann DCC loco is probably no gem!
We all assume that you have no blocks and no toggles that may be currently open to isolate blocks. So, if it is just feeders, and it works well now, it will work exactly the same way by disconnecting the bus leads to your current DC power pack, removing the power pack, and installing those two leads to the appropriate terminals on a new DCC controller base.
What you get in the way of DCC is a whole 'nuther question. I have stated in other threads that I haven’t found it in myself to recommend the first iteration of EZ-Command from Bachmann. It is too limited. It is like giving someone a car with a transmission where only first and second gear work. It’s a working car…but…
DCC costs money. Save up for a decent starter set from Lenz, Roco, Digitrax, MRC, or NCE, and then convert one loco at a time over a several month period as you accumulate the cash to do that. It means a delay, but when it’s all done it will be a chapter in your long life long past. Meanwhile you will have quality equipment running with full capability.
My [2c]
