Dave,
A question to help you answer your own question…
Why are the main crankshaft bearings and the piston rod bearings in automotive engines still hardened and sintered bronze?
Because the reciprocating forces would destroy a ballbearing or roller bearing.
The actual rollers, or bearing might be able to take it, but the race it rides in would scar.
Think about the force being put upon the rods in your car’s engine, thousands of time a minute…then carry that across to the immense weight and size of the side rods on a locomotive…it would shatter a roller bearing.
The axle bearings on a lot of steam locomotives were roller bearings, all they have to do is support the weight of the locomotive, the suspension absorbs most of the shock from the rails, and you want some play in wheel bearings.
Timken, and National Bearing made, and Timken still makes axle bearings for locomotives and rail cars.
The tolerances (clearances between the rod and whatever it rides on), and the clearance between the hole in the rod and the outer bearing surface is much, much closer or tighter with a friction bearing than you could ever get with a roller bearing, there is only enough “space” between the two for a thin layer of lubricant, something like a few microns, which the rod “floats” on, it never makes true contact with the bearing surface unless you fail the keep it lubed.
You cant make a roller bearing like that, there has to be enough play in the rollers to allow the one next to it to rotate or they bind against each other, which is way more play than a friction bearing has.
Last, note that almost all large engines, or any large machine that has rotating parts, like drive shafts, propeller shafts, turbines, connecting rods, piston rods, crankshafts all use “friction bearings” or block bearings for the simple reason that the tolerances needs can not be achieved with roller or ball bearings.
And not all friction bear
