Im switching to flextrack and was wondering when i buy the corkbed is it better to get the HO or N scale. Im using HO code 83. I thought ive read that people use N scale bed with Ho track. Thanks
If you are insetting ho track in concrete (see most recent MR project layout) use N-cork under the track and HO next to it. The difference in height of the cork is the height of a code 83 tie, which allows the styrene sheet to butt right up to the cork. Other wise, HO cork works just fine from what Ive seen, however Ive only put down 3ft of Code 83 so far on my home layout (engine service area using Walthers products).
For mainline use, Ii think most folks use HO cork. Some use N cork for sidings and yards, so that they are lower than the main. Others just lower the track to the base level.
Do a litle experimenting putting the track on the different pieces and see how it looks to you.
Have fun,
Richard
I use Midwest cork roadbed for all my main lines and 1/8" sheet cork for sidings and idustrial tracks. The 1/8" can be cut into strips to make thin roadbed. It comes in rolls to be used for cabnet shelf liners.
OK thanks for all your replys. I think ill just go with the HO corkbed from MW. If i dont like the width then i can cut it with a box cutter. Thanks again guys.
