A while back I obtained a brass bay window caboose in “as is” condition. It is missing the coupler pockets and mounting screws. I couldn’t even begin to guess what was the original screw size was. I do have a supply of KD coupler boxes with the little loops on the sides for mounting. Could anyone tell me what size screw fits those side loops? All I have on hand are 2-56 which are clearly too large.
0-80 x 3/16’’ brass round head (RH) screw will fit the side holes (little loops) in the Kadee coupler boxs and will extend though to fasten in to the body/floor of the rolling stock.
With what you are saying above is that you have two holes in the body/floor to mount a coupler box and not just one.
Thank you very much.Yes there are two holes under the bodey to accept the screws. Its a very nice caboose and the price was too good to pass up. Just needs a little TLC.
Reading between the lines, the gist of his question is answered by the 0-80 – that is what goes in his ‘little loops’. But this is not the whole of the answer he may need to know.
He does not say anything about any existing coupler-mount holes (or their threads) in the car as he purchased it. If he does not have two little holes corresponding to the loops, he will mark, drill and tap 0-80… using appropriate care and, I would recommend, either a drill/tap guide or drill-press arrangement to preclude breakage… or cement or solder captive nuts on the opposite side of what is probably a brass-sheet floor.
If he has a single large mystery hole, he needs to see if it is tapped, or there is or was ‘something’ on the other side for the (2-56) screw through the conventional center of box and cover.
Jeep, All my cabooses are brass, so I know what you are talking about.
I cannot get to any of mine for new pictures, so I will do my best to describe. I might have some pictures from archive.
The Asian brass manufacturers have all used non-USA-standard screws from my experience, and there is no rhyme-or-reason to the size they use. I have ten “identical” GM&O brass cabooses I use for my standard caboose model, and they have at least two different screw sizes from the builders.
I have an assortment of metric screws from NWSL that can be helpful, but believe it or not, sometimes they do not match up. I have wondered is there is a “Japanese Standard” that is different from metric. Japanese Standard 1/8" pipe thread causes havoc in the industrial world.
If I cannot find the correct screw from experimentation, I have drill and tapped the holed for 00-80 or 0-72 screws with success.
The small outer draft gear (coupler) box holes on brass cabooses are usually metric and commonly M1.4 x 4mm. It’s usually the same screw pitch found and used to secure the gear covers on the underside of brass locomotive chassis. IIRC, those are slightly shorter (M1.4 x 3mm).
I purchased a bag of 100 of both sizes and they have come in handy a number of times working on brass locomotives over the past few years.
My brass passenger consist uses the old style #5 coupler boxes with no center screw hole available in the car body. You need to find the correct screws or possibly drill slightly oversized and re tap for a #72 screw which should fit into the Kadee cover holes.
Or go whole hog and switch to #148 with snap covers, drill a center hole and tap for #56 and use Kadee nylon screws…
I put #148 whisker couplers into the #5 boxes under my brassies and I don’t care who knows about it.
I was thinking they were probably metric, and again I have no idea which size metric. But, now I have a starting point. I will have to carefully redrill and retap the holes to .080. I really appreciate the information everyone has provided. As always you guys and gals are a wonderful resource.
Maybe you meant 0-80 rather than .080"??? They are NOT the same. If you are going to go with a 0-80 tap, you need a 3/64" (or 0.047" OD) hole. .080 would be too large for even a 2-56 tapped hole.
He definitely did! and would get a fell surprise using that as a tap-drill size…
0 is the diameter size; 80 is the number of threads per inch.
There are tables, including some provided by microsize-screw vendors, that list the clearance for the different threads. There are also ‘kits’ with tap and clearance drills, a tap, and an appropriate ID guide tube to help prevent breakage; those take some of the guesswork out of converting from thou.
