Coupler Craziness
I am using kadee #5 couplers. The standard. I want to snip off “pins” or whatever you want to call them, but I still want to uncouple the cars without sticking a skewer into them or manually uncoupling them in any way. I have two ideas but I am posting this for more. My first idea is to hide strong magnets on either side of the track which will pull the couplers from the side. My second idea is to ditch magnets entirely, and have some sort of rod discreetly stick out under the car or under the couplers, and push up slowly, to simulate the amount of time it would take for a railroad worker to uncouple the couplers and walk to a safe place. Then, I can put actual model airhoses where they belong, hopefully the neat ones that join and break apart magnetically. Please brainstorm below at will!
Well, if you cut off the pins, no magnet, no matter how powerful, will work. The Kadee couplers themselves are non-ferrous, so magnets have no effect.
My main concern is basically “What are you thinking?”!
If you want to uncouple hands-off, which is what I do, Kadee had already perfected that for us. The Kadee magnetic uncoupling system is a beauty, and I seriously doubt your system will be anywhere near as elegant and reliable.
So… what is your motivation for removing the uncoupling pins and creating your own system? What are you wanting to accomplish?
-Kevin
https://www.smart-coupler.com/
https://www.precimodels.com/images/pdf/DCC-Uncoupler-Kit-HO_en.pdf
I agree with Kevin, but if you want to cut off the “pins” and add the magnetic airhoses, go ahead and do so.
After you’ve modified the couplers and added the airhoses, grab a skewer and take a leisurely stroll (you’re now the guy going to make the cut) and do the uncoupling manually.
I’ve never been overly fond of the appearance of the magnetic gladhands/pins, but they do work. You can simulate the time for that walk by leaving the couplers intact, too…simply wait for the guy to walk to the proper spot, then he can signal the engineer to give him some slack, so that the cut can be made.
You’ve titled the thread very aptly, but in my opinion, you’re looking for a solution to a problem which doesn’t exist.
As for the DCC solutions referred to by DSchmitt, I eschewed DCC because DC is so much simpler…there’s no way I’m going to wire a couple dozen locomotives, 40 or 50 passenger cars and perhaps 250-300 freight cars, plus untold numbers of MoW equipment for remote uncoupling when I already have that feature.
I can appreciate the ingenuity, but I’m sure that those same minds can come up with something that’s not only useful, but also practical.
I agree with wayne.
But I went another route…
If you want to get rid of the pins because of scale looks, the problem remains, as the Kadee (#5) couplers aren’t really so very true to scale…
I installed Sergent couplers. They open with a magnetic wand and looks absolutely terrific!
Sure, they demand that you do the same work as the real workers do. You line up the couplers, open them and slowly connect them.
To uncouple you add slack before holding the magnetic wand over the coupler, and then move them apart.
Kevin,That’s what I think every time I see a telephone pole come from the sky and go between today’s fragile museum quality freight cars then a giant’s hand pushes the cars apart…
Color me old fashion in you must but,for my updated freight car fleet KD magnets is still the best solution.
There is another alternative. Years ago (I should say, decades ago, maybe in the 1960s or early 70s) there was an article in MR by a guy who took his Kadee #5/10s (that is what we called them back then - Kadee never did make a #10 but they intended to) and simply reversed the metal pin so it essentially went towards the trucks. Worked just as good he claimed, which makes sense. You’d perhaps need a good long magnet to retain the “delayed action” feature but it seems fewer and fewer guys use that feature anyway.
A different article that I remember more distantly but same general idea - the guy removed the original pin and replaced it with a pin that went backwards then made a larger loop forwards so it ended directly under the couple draft gear box. I think his goal was to provide more metal for the magnet to work on so as to preserve the delayed action feature. [Amended post - this second article is November 1969 MR. I cannot find the first article and perhaps it was just a “helpful hint” or MR Clinic item that did not warrant an index mention.]
The virtue of both ideas is that the scale model air hose is not fighting for believability with a gross approximation right next to it.
The latest MR with that interesting article on magnetic ties makes a good point, one that as I age becomes more and more relevant. Once your hands start shaking even a little (or as in my case your eyesight is going south) there are many aspects of our hobby that become first a challenge and then simply not available, and using the skewer or swizzle stick to uncouple - perhaps even the Sargent magnetic wand or the Rix magnetic collar – is one of them.
Dave Nelson
I have some cars that do not have pins and they uncouple just fine with a screwdriver.
I also would NOT look forward changing my entire fleet for better technology, including couplers and decoders (I’m still not done installing decoders on my locos…). But I must say that these DCC-controlled uncouplers look pretty cool. Anyone out there have first hand experience with them??
Simon
I always thought that the Lionel 0/27 style couplers were the best design because they actually had knuckles which opened. I don’t know why nobody ever tried to shrink them down to HO scale. Some of them have a small lever on the side that you push down to open the knuckle. They seem the most realistic. Maybe some version of that would be good which used realistic hardware.
Yes, I always thought it odd that the c.1950 metal Lionel couplers were the most realistic ‘model train’ couplers made (except for being oversized of course!)
There was a company back in the '40’s-50’s that made O scale couplers that were designed to be used on older freight cars with the vertical brake staff. The coupler on that end connected to the brake staff, and turning the brake wheel opened the coupler. Not sure what company it was, or if they every made them in HO. Just happened that I picked up an old used car (wood craftsman’s kit apparently) with those couplers installed on it back when I was in O scale in the seventies.
Remote uncoupling could theoretically be achieved via a passive chip/active reader RFID setup, each car has a reader at each end that activates the uncoupling motor, just tap the passive chip on the roof at end you want uncoupled and done, I’m sure something similar could be done with magnets.
My very early American flyer passenger train has lovely knuckle couplers. They have a button on the underside to uncouple them.
I understand that the couplers are oversize, but that doesn’t appear anywhere near as noticable as the pins. Thanks for all the responses!
Maybe this would work for you.
Yes, I have an MTH loco that has DCC couplers. Not too useful on the loco, as all I cna do is drop the entire train or pick it up. The MTH ones work far worse than the DCC controlled Kadees - the open easily enough, but to get them to close you have to slam into the train harder than I really want to do. I did play with homebrew DCC couplers that used a small pager motor to pull the coupler open, those worked well, when closed they would couple up just like the kadees they were, no extra hard crash needed.
But - and it’s a big but - a decoder in EVERY piece of rolling stock? Dial up the car’s address every time you want to uncouple? No thanks. I’ll just play brakeman and use a skewer. I have many of the highly detailed kadee cars and also Branchline Blueprint cars with lots of delicate added detail parts, and I’ve never damaged anything using a skewer. But I haven’t taken the drastic step of clipping off the Kadee hoses yet. Instead I paint them like Cody does, oily black with a dot of silver at the tip (u
I’m sticking with the stick, skewer that is, to do the uncoupling. I have the Kadee hand held magnet uncoupler, works kind of OK, but as far as automating this, check around, a lot of people have been trying to develop the next new exciting lastest and greatest way to uncouple cars. Most require a decoder for each car, and may two? one on each end? No way. I’ve never damaged anything with the huge power pole coming down from above.
Maybe when it gets to the point of the brakeman stepping down off the train, walking along it, and doing his job, then getting on the ladder to ride the car to it’s next switch move, automated uncoupling will be a serious option.
Good luck with your brain storming, I’ve got some switching to do. [swg]
Mike.
To me the semi-scale head Kadee is a nice compromise between looks and functionality.
FWIW I am removing the trip pins from all my Kadee couplers, as I’ve never really liked the limitations of magnets/ramps etc. I’ve been uncoupling by hand for 30 years now, seems to work just fine. Just reach around one car from the top and grab the truck. Lift a little bit to disengage the coupler. Put the car back down. You can shift the car a little to the right to engage the coupler on the other car for delayed coupling (push the car along to drop it in a spur track for example). For me I think it would be more hazardous to cars to reach between them with a skewer or some other gizmo - peeling off ladders, brake wheels, and the like - than to do it my way.
Why are you trying to reinvent the wheel?
Kadee couplers have worked with magnets for years, with no issues, because of those grossly oversized “air hoses” that are on them. Without them, you can not use magnets.
Here’s my huge question though - How well can you see those oversized air lines when your train is moving? When my trains are operating, I don’t notice the oversized knuckles, nor those oversized air lines.
And yes, I know that Kadee calls them glad-hands, but most try to make them look like air lines.
