What type/brand of couplers are you supposed to use in the BW&R rolling stock kits… they don’t come with couplers.
The pockets are designed for Kadee couplers that come with the draft gear and box. The other option is adding a box over the hole for link and pin couplers.
-Brian
So I couldn’t use hook-and-loop couplers?
Sure you can as long as you can fit them in. It’s your car, do wat chew want!
-Brian
Okay, if I go with Kadees which ones should I buy?
