Couplers
I want to install Kadee couplers on my HO engines and rolling stock. I did a search and found an old thread that discussed it pretty well.
I have an Athearn EMD SW 1500. On the forum, one guy said he used #5 couplers on almost all his Athearn engines. On the Kadee site a #38 coupler is recommended for this engine. Which one should I use ? Maybe either of them will work?
Any advice will be greatly appreciated.
Thanks,
The Pirate
The problem with 5s on Athearns is the chassis carries power so you can end up with a short circuit between engines. Some guys get away with it but it is better to use on of the plastic shank Kadees.
