I was going to make this comment in the “Free Rolling” thread since it has come up there a couple times, but it’s probably far enough off the original subject to be off topic.
A car’s ability to couple freely rather than be pushed sown the track has more to do with couplers and not as much with weight of the car, grade, and lack of rolling resistance. All of the following is regarding already the exclusive use of Kadee couplers, not knock offs.
With new #148s or other Kadee whisker couplers, or shiny new #5s in centered Kadee draft gear boxes, I can’t MAKE a car roll down a grade without coupling at a decent slow approaching speed. If they don’t couple, it’s the couplers.
Off center: This happens mostly on rolling stock that has screw mounted draft (draught?) gear that can get turned out of center. Not aligned properly, no couple.
Coupler knuckle opening resistance: Somehow the knuckles have gotten gummed up, or even so old that a tiny bit of zinc pest has made them tight. (rare, but I’ve seen it) Painting couplers can do it. If they don’t swing upen freely, they won’t couple consistantly. And delayed uncoupling is impossible.
Knuckle face resistance: If the face of the knuckle isn’t shiny, but dull and flat, that will cause resistance to them slipping freely past each other on coupling. Again zink pest on some oldies contributed, but worse was when I once paiinted some couplers a realistic flat brown. I could push some of them all day until I slam coupled them.
Draft gear boxes: if the centering springs are restricted and the coupler can’t swing laterally correctly and /or recenter properly, in both directions, that’ll do it too. There have been discussions on making Athearn metal clips work better. I’ll add that whisker couplers work better in these than bronze centering spring plates, but NOTHING improves a #5’s behavior better than putting it in a Kadee box with the tapered out bottom p
