Covered flatcar load
I’m looking for suggestions for the cover of a load that won’t be seen. I’d like it to be close to prototype, but if those are mostly canvas I’m not sure how to do it unless I use real canvas which I think would be hard to work with because I want it to conform to the shape of the load somewhat.
There’s this:
http://cs.trains.com/mrr/f/88/t/219063.aspx
There are several YouTube videos on the subject:
Use paper facial tissue or perhaps spent dryer sheets or those packaged alcohol wipes. Toilet tissue is designed to dissolve in water. Not a good choice for modeling.
Good Luck, Ed
Canvas or tarps require careful shading and highlighting to make it look convincing. Indoor lighting will never recreate the reflective activity of sunlight on a large surface.
I love this Chooch casting with the torn tarp and a partially exposed load.
Without shading and highlighting, they just look like lumps.
To model a canvas covered load, I do not model the load. I work a slow setting hunk of epoxy putty into the basic shape and then emboss the surface with a piece of 120 grit sandpaper. That will look like canvas when painted properly. Most of the times it is difficult to tell what is underneath the canvas, so any shape can be convincing.
It is the folds towards the pull-points that are hard to get right.
-Kevin
I used a piece of old worn thin cotton bed sheet, cut roughly to shape, placed over the deck then fixed down by using “white glue” diluted with water. After it dried, I then trimmed the edges with a razor knife and painted “almond”. I didn’t get as good as edge as I would have liked and you can also see where I got a little heavy handed with the glue!![banghead]
Tarp by Bear, on Flickr
IMG_0922 by Bear, on Flickr
On this lifeboat I used tinfoil, which I had painted, then cut to shape, and glued in place using CA.
m42 by Bear, on Flickr
You could also try gift wrap tissue paper. It’s thin enough that you should be able to shape it nicely using a little water and glue.
I have assembled a couple of leftover building parts into the rough shape and I have an old wornout handkerchief ( no holes) that I am going to soak in brewed tea. If it’s a disaster, lost 1 tea bag, a table spoon of white glue and a worthless piece of cotton cloth. Also we have a can of spray starch that I might experiment with.
Mike
Gidday Mike, the theory certainly sounds good, and I like the economics!
Please keep us informed as to the results.
Have fun,
Cheers, the Bear.[:)]
Try experimenting with tissue paper. I have had good luck with dipping tissue paper in diluted white glue and draping over a load. Another option is to spray diluted glue onto tissue paper.
practice on scrap stuff and see if you like the results.
