just out of curiosity how serious is a cracked joint plate on both sides of the rail about 3 inches long vertically and look to be stress cracks should i tell someone mind you they are not all the way through though
If that’s a tie plate, don’t bother.
If that’s an angle bar pair broken on both sides of the rail at the place where the rail-ends meet - call somebody. NOW. (like the phone # at the nearest crossing and tell them how far from the crossing or some other identifiable point)
no not a tie plate theres some broken and look to not matter but yes it is the angle bar joint so i will call the railroad at lunch and i can show them where it is when i get home
Should be 4-hole angle bars around there. If it is broke in the middle, call. If just 1 bolt not connected (quarter break), that may not be a defect. Are you looking on the main line, or the FRA-excepted Mayville spur?
it is not totally broke just cracked i have the pics on my phone but i can not put them on here or i would. but it is in smack dab in the rail joint
WSOR 3801 PM sent to you!
