Creating Blocks with Bachman roadbed track
Has anyone created electrical blocks with roadbed track?? Is it possible and how to do?? Thanks
Bachmann makes a track section that has an insulated gap built in
http://www.hobbylinc.com/htm/bac/bac44597.htm
Dave Nelson
I just cut a gap in the rails. Nothing to it.
You could use Atlas insulated rail joiners to make blocks.
Maybe, and I do not have an example of the Bachmann roadbed track at hand, but some makes of that typoe of integral track system have electrical connections that either do not depend on, or double up on, the rail joiners.
Dave Nelson
The rail joiners on the Bachmann EZ-Track are the same as the Atlas code 100 rail joiners made for Snap Track and flex track.
A saw or a motor tool works just fine, unless you are of the sort that keeps moving things around.
[Y]Thanks to all for the info…I guess it can be done and I never knew anyone made track for this purpose either…[8-|]
