As long as my previous post was, I have a couple more comments.
The LogicRail GCP also has an output to drive a motor (Tortoise, for example) which will raise and lower crossing gates, if that is desired.
Also, the flashing sequence of lights at a prototype crossing is not what I would have anticipated. This will affect the wiring of the crossing.
I asked online in the Yahoo ‘Railway-Signaling’ group for information on the correct sequence. Here is what I was told, with no dissenting opinons:
" The way I have seen RR wiring diagrams is that all lights flash left then right then left, right etc on all poles. On each pole, the right side front and back are wired parallel, same for left set of lights. The other pole is wired so that it is synchronized with the other as far as left-right flash sequence.
If you could have a bird eye looking down view of crossing at the north and south poles, you would see four lamps on the left (2 on north, 2 on south) light, extinguish, then right side light, extinguish, the left side light etc."
…and another posted a video, which I cannot see since I cannot do youtube:
http://www.youtube.com/watch?v=D5fEOMFWYPE
So if you look at the crossing, you see the front signal left light flash when the ‘back’ of the rear signal left flashes. In other words, looking at the signals, you see both left, then both right.
This definitely affects the way you wire the lights, but most folks might choose to ignore this information, or to wire it according to their own preference.
Dick
