Curved Turnout Issue.
I have a few Walthers #8 RH turnout on my layout. All three tracks are caulked down securely right up to the turnout. The turnout itself is not caulked down. When my 2-10-4 goes over it about three times it goes out of gauge. I think I will have to fasten the turnout down to solve the problem which I would rather not do. Like I said I have a few curved turnouts on the layout but I can’t figure out why this one is causing me grief. Any thoughts on the matter appreciated. Thanks
Brent
Brent, I think there must be something else going on.
First, I expect your Texas type has a blind driver, maybe two? So the driver base is not the impediment here. That curved #8 will have an outside radius near 30-32".
One of the flanged drivers on the steamer is not loose, allowing the flanges to creep inward or outward on the axle? Pressure at some point in the traverse of the turnout may cause one wheel to migrate a bit, and later the flange snags the guard or frog point? I’m not sure where the snag is…
Have you actually gauged the points in five places down their lengths…they are quite long? Maybe one of them needs some tweaking, but I would doubt it…a lot.
Is the throwbar supported throughout its sliding range? If one side is a bit low, it allows that point to sag a bit, and the flange on that side will not get its guidance…engine slips between the rails partway along, or the pilot truck does it right away.
I would not glue the turnout. I have done a lot of cardstock shimming, lemme tell ya, but that is the way to get a turnout to work. It needs to be planar and well supported…no sagging places! But I have shimmed the throwbar occasionally to get the one point to rise up to where the flanges make contact and go the direction you want it to go when the points are thrown.
One other fix may be that you’ll have to glue/epoxy a thin shim against the flange face of one of the guards or wing rails at the frog. Sometimes they are set too far from the weight-bearing rails and essentially do nobody much good…certainly not a heavy long engine like the Texas type.
Crandell
Does the track actually go out of gauge - the distance between rails changes?
Or does the track go out of alignment where the turnout joins the 3 tracks?
In the 1st case, you have a failure of fastenings in the turnout itself. The “spike heads” on the ties are no longer gripping the rail. That would require the turnout to be repaired or replaced.
In the 2nd case, the turnout is chinging its location slightly relative to the 3 tracks. Replacing the rail joiners might help temporarily. But you probably will have to fasten down the turnout to keep the alignment between the turnout and approach track. Soldering the rail joiners would be another option to prevent turnout movement.
A 2-10-4 has a long rigid wheel base. And a fair amount of weight, especially if approaching the turnout at speed. And a curved #8 turnout has a much sharper inner radius than most people think. Some of the problem could be that the inner curve of the turnout is just too sharp for the locomotive.
my thoughts, your choices
Fred W
I had the curved tunouts. Because the frog points are so narrow, it’s easy to pick the frog.
Case in point, I had a walthers curved turnout (inner R24" outer R28") I thought my T-1 (R22 min) would easily take. Everything (2-8-8-2) (4-8-2) (2-8-4) (2-6-6-2) (2-6-6-6) but my lowly 2-8-0 and 0-8-0’s would pick the frogs and ride over them. Best I can figure it was trying to pick the path (the larger radius) to which it would go around easier. Shiming the inside rails before the frog didn’t seem to help much.
I found out that if you are going to use curved turnouts, that you need a much larger radius that what your train would normally negotiate.
If somebody has a solution, I would love to hear it.
The fact that the curved turnout is not held down by caulk leads me to believe that there is movement of the entire turnout. I don’t mean that it is faulty, just that it is movement. I nail down all of my track (all right, all ready, I know I should caulk it).
I have three curved turnouts on my layout, and all of them did what is happening to you at one time. And, yes, the 2-10-4 is a major culprit. I have two 2-10-4’s and they are what I use to bullet proof my turnouts. If a 2-10-4 passes the test, the turnout is good to go.
Anyhow, back to nailing (or caulking). I spend a lot of extra time nailing and re-nailing curved turnouts till I get them right.
One other question. Do all of your other steamers pass over this curved turnout without a problem?
Chances are pretty good, in my opinion, that it is neither the 2-10-4 or an out of gauge turnout. It is the movement of the turnout.
I have 4 curved turnouts on my layout; 2 are Walther’s/Shinohara, 1 is Peco, and one is a Fast Tracks built that I bought on Ebay. All have 32-36" radius on the outside. The Fast Tracks is by far the best of them all with virtually no problems, and I just got a second one to replace the Peco which is derailing my Hudsons about 10% of the time. I run my Big Boy, Challenger and Y6B without much problem. The Fast Track turnouts have 36" and 30" radii, but they are so smooth and flawless with all my locos. I tried everything I could with shimming and adjusting rails on the Peco and finally just decided to replace it with the Fast Tracks turnout. Just my thoughts on curved turnouts, which I think are just great looking on a layout.
Bob
Hmmm…I have five W/S curved Code 83 #7.5’s and a single #8, and the only slightly hitchy one, believe it or not, is the #8. Some locos do a hitch at the frog. Not on the tighter turnouts, and I run some hefty steamers through them in both directions. I also have a home-made #9 turnout that is just fine in both directions with all of my varied engines, diesel or steamer alike.
Crandell
If your turnout is going out of gauge, fastening it down won’t help. You need to find out what is changing and fix that.
What I do in such cases is to drill some really small holes in the ties next to the rail and actually spike down the rails so they won’t move once I get the problem fixed. By using the spikes, you don’t necessarily have to glue it down, and you also haven’t glued the rails in place in case it has to be changed.
That’s a good point. Run the 2-10-4 through the turnout until it derails. Then, get out the NMRA gauge and check the rails.
To me, “the turnout goes out of gauge” sounds like the rails themselves are no longer solidly fastened to the ties. They should be firmly attached to the plastic all the way. If not, the plastic has likely broken. You should be able to repair this using some CA, although this will be a brittle joint and may need to be redone every couple of years.
Where does the engine derail? When I think of curved turnouts, I think of flex track curving into all 3 ends. Flex track, in general, wants to go back to being straight track. So, the point where the flex track meets your turnout has sideways torque on it, and is a likely spot for a kink to develop. On my curved turnouts, that’s usually the problem.
Be careful of vertical alignment, too. Take a metal ruler and slide it along the rails lengthwise. The edge should stay in contact with the rails at all times. If there are gaps, or if the ruler can “rock” over a track joint, then the whole installation is not flat (or rather “co-planer,” since it should be OK if everything is on the same slope.)
What goes out of gauge? On the #8 curved turnout, the radius is so broad that it makes the sliding point rails very long. Of course in order to slide, they have no support under them, such as ties and spikes. So, when heavy locomotives run over the point rails, they can bend, flex, and separate out of gauge.
Could this be what is causing the problem?
I have #7 and 7.5’s and small locommotives and don’t seem have this problem, but the 8’s must be really long and flimsy. I remember reading about this problem somewhere so you might do a search for that topic to see if that info was on this forum.
I think the solution was to CA styrene strips under the rails. Stout enough to support yet thin enough not to impede operation, if that’s possible.
I would be interested in hearing about Peco curved turnouts from others since I have purchased 7 of them to use on my layout. Have others had problems with them as well? Am I nuts for using that many curved turnouts?
Dave
Hi Dave,
I’ve had no problems with any of my Peco turnouts including curved ones and wyes. The Peco PL 10 switch motor and PL 13 accessory switch work very well also.
Happy Railroading
Bob
If you have a spikable roadbed, you can easily spike the turnout in place because the W/S turnouts have spike holes already provided. As a matter of info, the radii of the #8 are actually 36/30.
Dante
Brent, I’m wondering why you’re reluctant to fasten the turnout in place. Having a turnout with moving parts being moveable itself sounds to me like an invitation for trouble. I spike mine in place when laying the track, and solder all of the rail joiners, too.
If the moulded-on spike heads have lost their grip on the rails, you can use spikes intended for handlaying to correct the problem. They don’t necessarily have to be installed through the ties, either. The photo below, while not a turnout, illustrates the general idea:
I use track nails the same way…drive them tight to the rails and let their heads cover the outer edge of the foot of the rail.
I like those blue spikes, Wayne. [:)]
Crandell
I’ve got 3 Peco curved turnouts. The turnouts themselves have never given me any trouble. They’ve been in service on main lines for 5 or 6 years now.
However, it is very important to get the trackwork right adjacent to the turnouts. My curved turnouts are on the older Code 100 part of my layout, and the track there is generally Atlas flex-track. This presents a bit of a problem. The cross-sections of the Peco and Atlas Code 100 rails are different. So, a rail joiner isn’t going to fit snugly on both rails. Since the flex track want to go back to being straight track, it’s necessary to firmly fasten that section down, and possibly shim it to maintain both horizontal and vertical continuity at the rail head.
This is one place on my layout where I found Atlas sectional track to be of great value. I used it as a “go-between” for the Peco-to-flex-track transition. A short piece of sectional track eliminates the sideways torque on the Peco, and then the other end of the sectional track mates perfectly with the Atlas flex.
I’m not the original poster, but this is a great topic - thanks for all the replies with tips.
As a matter of general interest, the actual inner and outer radii of the Walthers code 83 curved turnouts are not at all as claimed in catalogs, websites, etc. Users are advised to measure theirs before final track planning and installation.
I measured mine by drawing sample radii lines in a part-circle on a large piece of plywood, then placing the turnout over the lines to see how closely they matched. This makes it immediately obvious that these turnouts differ quite a bit from the advertised radii.
Here are my results with a set of three of these turnouts - first the advertised radii, then the measured radii on these samples. I do not consider this information set in stone - other turnouts with same designation and same mfr may differ, making the measurement quite important, in my opinion:
Walthers code 83 advertised radii:
#7.0 inner / outer advertised 24 / 28 in; measured 21 / 28;
#7.5 inner / outer advertised 28 / 32 in; measured 25 / 31.5;
#8.0 inner / outer advertised 32 / 36 in; measured 28.5 / 38.
Again, YMMV.
Dick Chaffer / Bozeman, MT
As I have posted in the past, I agree with Dick that the actual radii of the W/S turnouts differ from the advertised. I measured in a manner similar to that described by Dick; however, I verified my findings by carefully checking with the Ribbonrail alignment guides and found somewhat different radii than he did:
#6.0 inner / outer advertised 20 / 24 in; measured 18 / 24;
#7.0 inner / outer advertised 24 / 28 in; measured 22 / 28;
#7.5 inner / outer advertised 28 / 32 in; measured 26 / 32;
#8.0 inner / outer advertised 32 / 36 in; measured 30 / 36.
I agree with him: check them if the actual radii are critical to your layout.
Dante
Hmmm…I was less generous than both of you when I determined the error for the several #7.5’s I purchased. I used a trammel with marks every inch, and I found the inner route to be closer to 22", while the outer is near 28". I suppose it could be that I was sold #7’s.
Crandell
