Curved Turnouts
Does anyone know what the centerline radii are on the tighter Peco and Walthers curved turnouts? I have a specific situation on my highly space challenged layout where I need the inside radius to be 18 inches or very close. I’m using code 100 NS.
Thanks,
http://www.scalelink.co.uk/acatalog/Shinohara_Track___Pointwork__HO____Aiguillages.html
The PECO radii are very close to 18 for the inner, 22 for the outer. I think both of them are maybe an eighth of an inch less or so, which should work for you. I’ve got 2 of these, and they work great.
Peco catalogue quotes the radii as 17 1/4" and 19 7/8" (438mm and 505mm) for the Setrack turnouts. ST-244 and -245.
Walthers 2006 catalog lists the #6 1/2 TO inside radius at 18" and outside at 24"
I did all of the above and bought a Walthers (Shinohara) that was supposedly 24"R inside.
It did not look right so I bought the next larger size. Still looked wrong, but better (perfect match would have been in between like #7-1/2). Don’t know why neither fit, probably the radius specified is the radius at the exit not near before the frog. It’s more like an easement curve.
