Cut angles for raised wood roadbed.
Hi, I’m new to Garden railroading. I will be starting track work when the weather cooperates. I will be using a raised wood roadbed for part of the layout. The curve diameters will be 8’ (4’ radius) and 5’ (2.5’ radius). Can someone tell me what angles I need to cut my planks for the curves I am using.
Thanks for your Help
Karl
For a standard 24 sided polygon the angle is 15 degrees -regardless of the radius of the circle.
regards
ralph
Hi Ralph,
Thanks for the information should be very helpful.
Karl
NEVER PUT A CUT UNDER THE JOINTERS AND REINFORCE YOUR CUTS.
Dave
If you are using wood like 2 x 6, be sure to turn the wood so that it will crown, not cup…
Looking at the end of a plank, you want the rings to curve like a frown not a smile.
When the wood warps (and it will) you want it to crown, like a road, in the center.
Regards, Greg
Howdy Karl welcome aboard; Have you considered the “plastic” wood products now on the market? Some garden railroaders have used it what they call “ladder” construction. I used it on a ten foot long curved trestle. It comes in 8’ lengths and easily bends, can be worked like wood (I cut it on a table saw), it won’t rot and can be nailed, screwed and glued.
Good luck, Rob
Remember that the synthetic wood needs supports basically twice as often as wood, it sags. (Info from the manufacturer on using it on decks)
Regards, Greg
Hi All,
Thank you all for your advice, suggestions and information. It will be very helpful.
My plan is to use 2 X 6 (1 1/2" X 5 1/2") cedar decking for the elevated road bed. The ground level road bed will be crushed stone in a 2" X 8" trench.
Thanks again
Karl
