I have a proto 2000 blue box loco i have using a dremel to mill out some of the weights fir a decoder, its cutting easy enough, of course it makes a mess, i cleanup after cutting and wash up, is this stuff lead or lead free, just want to make sure its safe to be grinding this stuff
There is no lead in these castings. Most of them are a zinc alloy. FYI, Proto 2000 were not Blue Box locomotives, Athearns were, so which do you really have?
I have access to a Milling Machine & other than files, do not like to grind too much anymore. I always wash up just in case as well. I know that doesn’t really answer your question, but that is what I do.
I like the finished look & precise mounting when using a Mill & having a good plan & test fitting.
Yep, looks great. But first price a milling machine, then price a hacksaw…[;)]
If you’re careful, the hacksaw will do almost as good a job as the milling machine, but won’t look so classy. You’re going tp put a shell on it anyway, so what the heck.
Whenever you do work on the weights/chassis always a good idea to clean up well, because a tiny chunk of metal can really tear up a plastic gear.
