Well, Santa asked for a list. So he (really, she) doesn’t pick the wrong one, I’d like to provide a supplier and size for one of those “self-healing” modeling mats. Seems like there’s lots of photos of bashed and detailed power and rolling stock that have appeared on these forums with these mats as a backdrop and so I’m sure there’s a healthy spectrum of opinion out there.
I’m inclined to go with a 12x18, with ruled scales in both English and metric, and also with the apparently standard half inch grid. I’ve run across notices that at least some of them produce carcinogenic vapors when inhaled by California lab rats over a period of 600 years. Not so sure this is a make or break issue as I’m jaded enough to assume anything that doesn’t smell won’t fry my brain further than it already is. Please cough up your preferences. Time’s a wastin’. [8-|]
After six months this thing is still giving off an eye-watering odor that is pretty pervasive. Otherwise it works pretty well although for most cutting I still place a scrap of shirt-cardboard under my work. I don’t particularly find the printed markings of much use in the model work that I do. Maybe it is handy for some sheet-goods.
It could have been a certain batch or perhaps they made changes to the formula. I worked 38 years in a factory that used some pretty stinky chemicals so I’m not immune to foul odors… but this thing [+o(]
I went with a Hobby Lobby mat, they have several sizes. With their 40% discount coupon the price is right too. I’ve had the one I use daily for over two years and its doing great and I really beat it up.
Mel
I suppose that it depends on what you need to cut. I have one, but seldom use it. I generally work with styrene, so it’s score-and-snap…no cutting necessary. I do cut decals with my X-Acto, but a cutting mat is pretty-well useless for that if you want any accuracy. I also cut small diameter wire (up to about .030" for brass), and thin sheet brass with a knife, but all of those applications require working on a hard surface. I use a sheet of glass, and it’s my usual work surface, too. It does require that the blades need to be sharpened more often, but for accuracy, can’t be beat.
For those reasons, I can’t recommend any brand of cutting mat, other than it should be reasonably priced.
I use a mirror for precision cutting, like thin brass and decals. I also use a plastic board for other stuff, like sheet styrene. I don’t know what type of plastic they are, but we buy them at a restaurant supply store, as the wife buys her’s there. I think they are polypropylene. I don’t need the scaled square thing.
I found a piece of plate glass, approx. 1 1/2’ X 3’, about 3/8" thick, of all places, laying beside a dumpster. I use it for all my cutting and all my other work too. It’s a permanent fixture on my work bench.
I’d guess the fact that the mat compresses during the cutting action. It’s perhaps not as much of an issue when cutting is done as a slicing motion, but definitely causes problems when cutting with a chopping motion, which is the best way to get clean cuts with decals (slicing raises the paper on both sides as the blade passes, which in turn lifts the edge of the decal, making it more difficult to hide once applied. Chopping, on the other hand, pushes the edge of the decal downward). If you’re cutting wire with a knife, it needs to be firmly supported - on a cutting mat, the blade will bend the wire, rather than cutting it.
I’m sure that there are uses for cutting mats, but they’re apparently ones with which I’m not familiar.
Mine is an 18 by 24 mat made by “HobbyCo” that I bought at Hobbytown USA in Brandon, FL.
I replace it about once a year. These are really easy to find. I like this one because it is exactly the same on both sides, so when the first side gets worn, I just flip it over.
Now there are at least three of us. In some circles, this constitutes a sufficient number to officially organize. I will be glad to nominate you as President with Kevin as Membership Coordinator. As a former federal Budget Analyst, I would make a good Treasurer. Let the snide comments begin, especially regarding the latter.
If this indeed became a new thread, I’d bet it would garner a fair amount of attention - and response. By its nature, ernest model railroading generally seems to accumulate an inordinate amount of stuff and a hefty number of what might be euphemisticly described as “current projects”. Talk about clutter!
Here you can see two different “surfaces” I’ve recently used. The white one is a sheet of food-grade Lexan left over from a job at GE. The top photo is the latest “Alvin” brand cutting mat. My bench is a seventy-year old 38" x 60" drafting table.
The drawing surface below the cutting mat is pretty beat up and whatever it is glued to the hard-maple surface with will not allow it to be peeled off.
I simply renew the cutting mat, first by turning it 180 ° then flipping it over. Maybe every two years I replace it with something fresh.
When I have a decal job or something requiring more precise cutting I have a 8" x 12" sheet of laminated safety glass.
Well, Mike, here’s the office desk top, AFTER I cleared off most all of the MRR stuff and transferred it upstairs to my new, second workstation:
And here’s #2, for which I’ll secure both a mat and a glass plate or polypropylene board, or both. Lighting is to be upgraded. Needless to say absolutely nothing has yet been done at this desk (IKEA rocks). Glad I took a picture of it. My sweetie says that it’s likely never to be this clean again.
