Cutting up the CNJ Bronx Terminal....
Hi,
Well, not destroying it, just making some badly needed modifications.
When I designed the layout, I made a mistake in placing the edge of the waterfront where the carfloat docks. If I left it the way it was, I would have to change the geometry of the track leading into the float bridge, and I think it would have been quite noticeable.
I made a series of videos showing the repair. It involves power tools!
These can be seen at my site here…
http://www.bronx-terminal.com/?p=3189
There are a few other videos of the progress so far on the layout, which I am hoping to have operational for the NMRA Train Show in Hartford this July.
Intresting Videos but i had trouble hearing the first one\
even though the sound was turned all the way up
maybe my hearing is finally going bad
Tim
When I saw the title I was horrified,until I watched the video.
I’ve been following this series of yours for a long time,great work!
I assume no dogs were harmed in the filming of this video[;)]
Steve
No its not just you.[swg]
I had trouble too.
tim
Hi,
Odd, I can hear it quite clearly, although there is a bit of room reverb present in the video.
Are you sure the volume control on the YouTube player is as loud as it can go in addition to adjusting the volume of your computer?
YouTube has its own volume control that has tripped my up on more than one occasion…
-T.
PS - Dog survived video production well.
Whew. I thought you were not going to be able to finish it. This is just such an interesting project, that I can follow it even if it takes years to complete. It’s more than just model railroading; it’s history itself. Maybe, when it’s done and you’ve decided you need to move on, you could donate it to the Smithsonian.
I’m serious about that. This particular model deserves a wider audience than just us.
I’ll second that last motion…
Steve
Luckily I had already read about and watched this on the blog site so the title didn;t scare me [:D]
I don;t think the problem is the volume being too low, it’s that there’s a huge dynamic range - when you turnt he volume up enough to clearly hear when Tim’s 10 feet fromt he camera, when he is back to close up it’s too loud - or when he turns on the saw. It’s never an issue on the close-up construction videos. I’d suggest a small wireless mic so sound level is not dependent on distance from the one built in to the camera, but of all the things being filmed, only a very few would need it.
Hi from Belgium,
I was afraid when I see you gluing all the track of the Bronx Terminal, because I experienced some bad issues when gluing track on my own layout.
I follow your series nearly everyday and I am waiting for the first loco run.
Good luck for the next chapter.
Marc
