CV help
I finally got my BB SW7 w/ Digitrax DZ123 back together and on the track. I test ran it and it runs fine (for what it is). The only problem I have is that I must have mixed up the headlight leads when I was soldering.[D)] The lights now operate opposite of the direction of travel (ie. rear light on when moving forward, forward light on when moving backward)[banghead]
I know there must be a way to re-map the functions to correct this can somebody set me straight? What CVs do I change, and what would be the correct values?
As always, thank you for your collective brain power![bow]
CV 33=2
CV 34=1
David B
Thank you! (and DecoderPro[:)])
…You should learn how to use it. I wrote a tutorial and it should answer all your questions.
David B
I read it (great tutorial BTW) and actually downloaded the software, but I haven’t had the opportunity to sit down and install it and try it out. My “play” time is currently severely restricted - my wife is pursuing her nursing degree and working full-time, so I spend most of my “free time” carting the kids to and from their activities and playing Mr. Mom (gasp!)[C=:-)]. This is why i truly appreciate your response - it allows me to move forward without taking another side trip.
Your willingness to share your expertise is an asset to this forum. ( I promise I will “hit the books” once time allows[:)])
Thanks again[bow]
Sounds good!
David B
I found your tutorial very helpful! I have used it on several ocasions (without a connection).
Where might one find your tutorial? Thank you in advance.
http://cs.trains.com/forums/1282296/ShowPost.aspx
I never used it but I can search for it.
